...but on the OVHD channel search, the tuner status is not found and shows 0% strength, & quality. I need a fixya..LoL
SOURCE: satellite dish receiver error LNB Drift detected
that's not true i work for dish network if u have an LNB drift of -8 or +8 you can get a free lnb service call and they can come out n fix at no charge
SOURCE: Suddenly the Tuner mode reports "No Signal"
Just a solution.
I attached a video recorder., and selected the video channel.
I was able then to see the channels through another AV slot extension.
Then I reset the TV to factory settings.
Samsung full HD reset code is 0000.
I used the original remote control.
I pressed the button TV/DTV to switch between mode., and from the menu I started
the option to scan the channels automatically.
Because the VCR was still connected it looks like it was forced to admit the channels.
I turned off the VCR and click on the TV the remote control for a known channel ( alternative control used) and surprise ... The TV started to react according to expected.
I disconnected then physically the cabling from the VCR and plugged in directly on back on the
wall connector. All is ok.
What was the reason ?
My wife dropped the alternative remote control ( not the original one) on the floor, and apparently an strange code was sent to the TV., which suddenly displayed " No signal".
I hope this can work for you.
Kind regards
Sanchez
SOURCE: how do i fit a dual LNB so i can change channels
HELLO
A word of warning! Do not attempt to split any feed coming from a single output LNB to another satellite box - you will be asking for trouble!
Now for the solution. If you are using a standard sky minidish you will need a 40mm adaptor kit, a dual output LNB and another length of satellite cable (Webro WF100 prefereably) but I suppose RG-6 will do the job providing it is not too long (around 10-15 meters or so) a couple of F connectors and self-amalgamating rubber tape.
Power off everything! Remove the old LNB and to do this you'll notice a plastic rivet on the LNB arm of the dish which must be removed. When you have done that and the new LNB is place (don't tighten everything yet), connect your current length of cable to one output and the new length to the other (finger tight should be fine) and make sure BOTH of your boxes are connected. Remember to waterproof those LNB connections.
Power on! You should be getting pictures - if not the LNB will need skewing round a bit. Look at the dish from the front and turn the LNB in a clockwise position say the 2 o'clock position - that should do the trick. Then tighten everything.
I wish you well with it - good luck! (:-)
Testimonial: "Thankyou Tony,most helpful Best Regards Rob Allen"
SOURCE: Humax 8000T not used for a while, now says
sig strength 29 is too low to lock onto. Humax needs 50+ to lock ideally 65+
is the aerial ok? try the set on someone elses aerial. If no joy then its possible the tuner is duff...but thats virtually unheard of.
SOURCE: added a 322 reciever to
Is TV 2 off the 322 receiver being back fed from the receiver or do you have a direct connection to the 3rd room? If it is a direct connection, you would screw the coax from the 3rd bedroom directly to the TV 2 Home Distribution channel 21-69 out port.
If you are back feeding, you need 2 diplexers that connect 1) by the receiver and 2) between the receiver and the 3rd TV. The back feeding will use the same cable coming from the dish to the receiver.
If you have any other questions, please don't hesitate to ask.
