Question about Golf
My ezze go elect golf cart has no feed to ignition or reverse buzzer so cart is dead TXTPDS model
Posted by Leon Rusteberg on
5 Related Answers
golfcartman
  • 34 Answers
SOURCE: 1999 ezgo golf cart.need to know the whole wireing
When you removed the batteries, a certain procedure MUST be followed. Key switch off, switch to tow position and shift lever in reverse. You must wait until the beeper unit sound dies out then remove the wire from the most NEGATIVE cable. Place in Neutral before installing new batteries. There is a specific sequence to putting the batteries in an EZ-GO cart. Failure to follow this procedure will kill the controller. The Key switch must be off and the maintenance/tow switch MUST be in the tow position when connecting the batteries. Any of the above will cause the controller to fail, due to improper discharge of the PRE-Charge capacitors.
Posted on Apr 22, 2010
Derek McClellan
  • 52 Answers
SOURCE: 1997 e-z-go elect. golf cart
If Gas I Would check to make sure the Belt is still connected to the Axel and the motor, there will be a V shaped clutch that the belt rides up and down in. As the RPM's on the motor go up the belt goes further down, If the motor is not getting to high enough RPM then its not catching. Hope This Helps!!
Best Wishes and Good Luck!
Posted on May 05, 2011
jim nicholas
  • 3 Answers
SOURCE: Can I leave my 2004 ezgo golf cart charger plugged
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
Posted on May 15, 2012
searcher1974
Bobby Blevins
  • 229 Answers
SOURCE: why does my golf cart only go in reverse
Its not reversing the polarity at the forward/reverse switch/
Posted on Sep 25, 2012
emissionwiz
Marvin
  • 85239 Answers
SOURCE: Golf cart will not start
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems.
Posted on Sep 28, 2012
07 Yamaha G29 golf cart has a bad TPS. With a bad TPS, would the main solenoid still operate? Reverse buzzer is not working as well. Trying to determine if the controller is bad.
Should still operate solenold. You also have a stop switch in the floorboard, it will connect when pressing on pedal.
Aug 30, 2017 | Golf
Yamaha electric golf cart 36v at motor but won't move reverse buzzer works has new batteries solenoid clicks Any ideas
I would make sure that the solenoid IS working even if it's clicking.
Make sure that the positive voltage is on the field side when it clicks.
Jun 26, 2017 | Golf
Need wiring diagram for forward reverse switch for a 1995 club car golf cart not finding diagram where i am suppose to look,
Finding a free service manual for that golf cart might be difficult. You just might have to bite the bullet and buy one.
Jul 29, 2016 | Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
How do I connect 36 volt battery charger to electic golf cart?
Maybe you have an Ezgo cart? Black is negative, white is positive, and the small red wire is connected to the white inside the charger receptacle.
Sep 04, 2015 | Golf
Yamaha Golf Cart won't start
did you leave the key on and kill the battery or a light or something double ck that battery , they will still light up the ignition and lights and ll but does not have enough to crank the starter , that is what is sounds like to me be put a jump on it or charge it and try again , when you turn on the ignition does the lights light up on the dash panal if so the batter is low
Mar 26, 2014 | Yamaha G-20 G20-g22 G-22 Golf Cart Tune Up...
Why does my golf cart only go in reverse
Sep 24, 2012 | Motorcycles
Golf Logo
282 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
