Currently its almost to buy a complete new gear box for only 1 worn gear shaft can it be because nowadays much brands deliver only complete gear boxes depending on which model and or brand . there is an gear-shaft worn in the box Milwaukee has also for most models complete gear boxes , Makita Panasonic Hitachi deliver for most models separate parts. I dont know how it is for Ryobi in your Country.
SOURCE: Dewalt 12v Cordless Drill. Same speed in position 1 or 2 ???
yep and with this model you are not alone! take it back and exchange it make sure it works before you leab]ve the shop
SOURCE: Jammed 2 speed switch
sometimes you have to rotate or just try to move chuck a little to align gears then try to change
SOURCE: Cordless drill question
1/2"
A 24 position clutch controls torque output. 2 speed range gear box for
high torque applications. Auxiliary handle with metal depth stop rod.
Has an overmold grip handle for added comfort. A Mag Tray holds screws,
small bits and hardware, etc. on foot of drill for easy access. 1/2 Ft.'
heavy duty keyless chuck for quick and easy bit changes. Removable 2
position level for convenience and accuracy
Contact Customer Service:1-800-525-2579
"RYOBI" is a registered trademark of Ryobi Limited and is used by One World pursuant to a license granted by Ryobi Limited ' Privacy Policy
