Question about GPX Audio Players & Recorders
I have a GPX ml552b mp3 player.I recently found the missing usb cable for it,but now I hooked it to my op and it says device not recognized.any suggestions?
Posted by Forrest Stair on
Bill Boyd
    Top Expert:
  • GPX Master
  • 53,816 Answers
Get the driver for the mp3 unit
Posted on Sep 22, 2018
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: won't recognize connection
proper software is not installed
contact your vendor for proper update
Posted on Jan 07, 2008
Anonymous
  • 28 Answers
SOURCE: Computer Won't recognize MP3/MP4 Player
Go to device manager. Remove all USB ports. Re-boot. See if that workds.
Posted on Jun 14, 2008
Anonymous
  • 4 Answers
SOURCE: Computer doesn't recognize MP3 player -
I had the same problem, all you have to do is first turn on the Mp3.Then go to settings. Then go down to USB mode. It will probably say, auto detect.But instead scroll down to MSC. If that doesn't work try MTP.
Posted on Jul 15, 2008
Anonymous
SOURCE: computer does not recognize usb device
Go into the settings menu, from there, go into usb mode...there are two settings: mtp & msc... my player was using mtp and wasn't being recognized, so I switched it to msc, and the computer recognized it.
Posted on Oct 24, 2008
golu_fixya
shivam raj
  • 213 Answers
SOURCE: My samsung yp-u3 mp3 player is not recognized by my computer
hello sir go to my computer> properties>hardware > device manager >universal bus driver>right click on it> update driver>
then1
1.yes this time only> next 2.choose advanced option>next 3don't search i"ll update from........>next4.click on show campatible> next> next 5. now it updated then restart you computer
Then try to format your drvice sir
hope this helpful or if problem stillplease type in comments
Posted on May 06, 2009
I got a GPX ML552B and it wont turn on, and when i plug it into my computer it doesn't show up like my computer doesn't recognize it as a device. I tried letting it charge several times but it still...
help I have this play too from Family Dollar for 18.00 plus tax and I heard u have to charge it by computer then when I charge it after 8 hrs. I do expect it to work. help!!! even on the site it says press play/pause for 3 seconds. to power on I tried and tomorrow i'll text back after charging again.
Sep 25, 2013 | GPX Ml552b Black Mp3 Player 4gb 1.8" Lcd...
Usb devices error
Stop Nokia Lumia Music Player.....
Watch solution at forllowing youtube video:
http://youtu.be/uTyhAdTJMpI
Sep 07, 2013 | GPX Ml552b Mp3 Player
How do I delete unwanted songs from ML552B Digital Media Player
Connect the unit to your computer the same way as when loading music onto it. Then in the Explorer window right-click the song to be deleted and select "Delete".
Mar 26, 2013 | GPX Ml552b Mp3 Player
Need user manual
You may download a copy of the manual here.
I have a GPX mp3 player (#ML651B), and, for some reason, the computer will not recocnize it, so that I may download music files to it. It plugs into computer via USB cord, the player is new, Computer is...
First of all try it on a different computer, if that still doesn't work try Formating the mp3 and reseting it to the default settings through the System tools menu.
Anyway here is a link to the manual in-case you need it: www.gpx.com%2Fowners_manuals%2FML651B-IB.pdf
Mar 05, 2011 | Audio Players & Recorders
My GPX player, model number MW259BU, will not work. When I plug it into the USB port, Windows gives me a message that it is not recognized and the device is malfunctioned. I updated Windows Media Player...
try
these steps:
1.plug your pen drive in your computer.
2.then open Control panel.
3. open administrative tools.
4.open Computer Management
5. a window label computer management will appear.
6. click disk management
7.locate you pendrive and select delete partition or format it fat 32 or other format convenient for your usage.
ok
hope this will help
cheers
uttam
Jan 21, 2010 | GPX MW3837 MP3 Player
My computer doesn't recognize my gpx ml648 mp3 player when it is plugged in.. why not?
I am going to type up what the owners manual says for this:
1. Try running Windows Update to see if there are any Service Packs they have available. You can do this by going to www.windowsupdate.com
2. Scan for hardware changes. To do so, open Device Manager. This can be found by right clicking on My Computer. Choose Properties from the menu that appears, In this System Properties menu, click on the Hardware tab. From the Hardware tab, click on Device Manager. Within Device Manager, there should be a listing for Portable Devices. If there isn't a listing for Portable Devices or the listing shown is highlighted with a question mark, right click on Universal Serial Bus Controllers and select Scan for hardware changes.
3. If no devices connected to a USB port can be recognized, try connecting the mp3 player to a different USB port.
Also, if you are using a USB extention cord - stop. make sure the cord from your player is directly connected to your computer.
Nov 01, 2009 | GPX ML648B MP3 Player
Unit doesn't link with pc
1. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as MTP Device.)
3. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as USB device.)
4. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
5. Double click & open Tools, and run Setup.exe to start installing Video Conversion Software tool.
6. Select defaults options and finish the installation by clicking on Close or Finish.
7. If asked, click on Continue Anyway on Windows XP or Install this driver software anyway on Windows Vista.
Dec 27, 2008 | GPX ML648B MP3 Player
Gpx mw3837 problems
USB device not recognized, when MSP3 player MW3837 is pluged in. Please help thanks!
al.
Mar 23, 2008 | GPX MW3837 MP3 Player
GPX MW6815DT trouble
For those that still use this mp3 player here are some things you need to know.
the gpx mw6815dt can operate as a media player or a usb storage device.
you need to change which state it is in via the System option.
Enter (Sys) from (Mode) go to (Online Device) enter (Mode) select USB Disk or Media Device. When you connect it as a USB Disk you will see all files not shown when connected as a Media Device using windows explorer. Also I suggest you make sure if you format the GPX you stay with the FAT 16 file system.
Note: DRM only works when the gpx is in Media mode.
If you have an SDcard installed you can access it via windows explorer or media player as a usb device only. With media player 11 you can still sync both the internal and sd drive with your library however you won't have drm options since your in usb device mode.
Note: in order to have both usb drives avaiable you need to use the Multi Drive option under (Online Mode) in the (System) menu, other wise you won't see the sdcard.
Feb 15, 2006 | GPX MW6815DT MP3 Player
Top GPX Audio Players & Recorders Experts
Jean Sintulaire
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
