Question about Electronics - Others
Cant find any direction on how to format a 64 gb microsd card to fat32. i dont want buy anything. just help
Posted by [email protected] on
Terry
  • 11,377 Answers
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: FAT32 format, how to do it in Windows XP?
Windows 2000, XP, Vista can format your drive into NTFS and it sounds as if you're already there. If you want to format in FAT32 they'll do it, but they will limit partition size.
The way I've done it is to use linux. there is a form of linux called "knoppix" which is a CD or a DVD which will boot your PC and turn it into a linux box running from the DVD drive. Linux will allow you to format your drive in about a dozen ways, so choose carefully. If you are tech savvy and adventurous, this is fun and not dangerous (providing there is not data to lose). On the other hand, if you want safety without the hand-holding, there is formatting software you can buy to do this in windows, but the modern Windows systems will not of themselves give you a massive partition in FAT32.
Posted on Dec 27, 2008
Anonymous
  • 13 Answers
SOURCE: LG Fusic 550 Sprint - Memory Card Error with 8 GB Sandisk MicroSD
Believe it or not, a lot of the older phones (an even the newer phones) will not support the 8GB memory card. Most of the phones on the market that support 8GB cards are the smart phones and PDA's. There are a few standard phones that support it but not many. Unfortunately, the LG 550 is not one of them. :o/
You may need to take it back and exchange it for a smaller one.
~*~ Your Rating is Greatly Appreciated *~*
Posted on Feb 23, 2009
Anonymous
  • 404 Answers
SOURCE: Sandisk microSD 2GB : well formatted on cellphone but...
its not the adaptor its the card hence it gives you the error means it can access it. is the card working 100% when you plug it back to the phone?
Posted on Mar 09, 2009
Anonymous
  • 256 Answers
SOURCE: unable to format 64 gb pen drive
Plug your pen drive into a computer that is on. In Windows Explorer, find the pen drive and right click on it and select "Properties". Select the "Tools' tab and then the "Check Now" button in the "Check the volume for errors"Box. Select both oxes and click "Start". Hopefully this will recover all of your drive. If not, the drive has been compromised (toasted). Then you should check with Kingston to get a replacement.
Posted on May 28, 2009
Fixe_You
Jalal Sordo
  • 1800 Answers
SOURCE: when i try to format my microSD 4gb card my pc freezes
sorry that occurs when th internal memoy is corrupted.
Posted on Jun 22, 2009
Tip
How to recover SDXC Memory Card
Storage is getting cheaper, smaller while offering higher capacity every year. 64 GB memory cards are extremely common in today's smartphones, digital cameras, tablets and media players. Due to their sheer capacity, a single failure can cause a local catastrophe with that much information being gone.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-0_0.jpg
Fortunately, the market offers numerous data recovery tools that can help you get your data back. But there is something about these cards you should know before you reach for a data recovery tool.
Flash Chips: Riddled with Defects
Can you believe you can buy the whole 64 gigabytes of fast, high-quality solid-state memory for as little as $20, or does it sound too good to be true? Why is an SSD drive of said capacity three to four times as expensive as a much smaller SD card with similar capacity? Isn't it using exactly the same type of memory, just in a different shell?
In fact, you can't really buy 64 gigs of high-quality flash memory for under $20, and there is a good reason why SSD drives are that much more expensive compared to SD or micro SD cards. The answer is buried in the question itself. Why you can buy a 64 GB microSDXC memory card off Amazon for not much more than $20, the actual flash memory the manufacturer puts in these cards is of a completely different quality compared to that of a typical SSD drive.
So how exactly are manufacturers able to achieve these unbelievably low memory prices? They do smart tricks to make the memory card appear as 64 GB of contiguous space while in fact the actual chip is riddled with defects.
Each memory card employs a tiny microcontroller that maps flash cells to logical addresses. The memory chips are manufactured with abundant capacity. During the manufacture, the chip is tested for defects. Unreadable blocks are simply mapped out and become non-addressable and inaccessible from the outside. Bingo! We've just turned an imperfect chip into a perfectly usable memory card. These tricks are nothing shoddy; they are used by all SD card manufacturers, and they are part of the published SD standard. If not for these tricks, SD memory would probably cost the same (or more) as today's SSD drives.
Now when you know the truth about today's flash chips... can you trust them your data? In fact, you can. Granted, SD cards can sustain a much more limited number of write cycles compared to an SSD drive. When one or more data blocks reach their end of life, the built-in microcontroller of said SD card is supposed to take them out of circulation and assign their logical address to another (working) cell. But what if that cell contained some system information such as a part of a file system? If this is the case, the memory card becomes corrupted, and you'll need to use special tools to extract information from that card.
Recovering Data from SD Cards
Luckily, we have a large number of data recovery tools available on the market that claim to recover the entire content of your memory card. But were they really tested with any of those memory cards in their compatibility lists, or do developers simply assume the recovery will work based on the same principle as traditional magnetic media? In fact, I've seen both and in between. Some products can recover all types of SD cards as they claimed, some other tools can't deal with SD cards at all, while some other tools can only recover SD cards up to 32 GB.
Wait a minute... Why the 32 GB limitation? Why some of the tools can recover 32 GB cards, but fail miserably when reading a 64 GB one? Should the tool either work or not? The reality is more complex than the numbers. While SD memory cards up to and including 32 GB conform to the SDHC standard, larger SD cards (64 and 128 GB) conform to a different standard called SDXC.
Recovering SD, SDHC and SDXC Memory Cards: Is There a Difference?
There is in fact a big difference between smaller (up to and including 32 GB) and larger (64 GB and up) SD cards. The former conform to the SDHC standard, while the latter use the newer SDXC standard.
For you as a user this can mean two things.
  • First, if you are using a 64 GB memory card, make sure that both your portable device and your computer's SD card reader advertise support for SDXC cards (or simply put, they explicitly state support for 64 GB SD cards). If your card reader is old and can only support SDHC cards, you won't be getting anything but errors if you try to read that card with your computer.
  • Second, SDXC cards are formatted with a different file system. Let me explain. When SD cards initially appeared, they used FAT32 as a file system. FAT32 was good enough in the old days. However, this file system has inherent limitations, restricting maximum file size to 4 GB. Just a few years ago this would be a laughable limitation. Today, a typical HD video will already run you more than said 4 GB. If you try to save a large file onto a 32 GB memory card (formatted with FAT32), the write operation will fail.
This is why the SD consortium decided to use a different file system for the new generation of SD cards. 64 Gb, 128 GB and larger SD cards come formatted with exFAT.
exFAT is a new file system developed by Microsoft. exFAT is based loosely on the original FAT32. However, exFAT does not have the limitations of the older FAT/FAT32. exFAT is extensively used in portable electronic devices due to its lightweight design. This was one of the reasons exFAT was selected by the SD consortium as a standard file system for the SDXC format.
Are there downsides to exFAT? There's one, but it's a major one. While exFAT is designed and owned by Microsoft, it's not free. Microsoft requires manufacturers pay licensing fees for using exFAT in their devices. As a result, this has become a limiting factor for many portable electronic devices, especially inexpensive ones. This is one of the reasons why you can use 64 GB SD cards in some devices but not in others.
As a result, when recovering data from a 64 GB SD card, you'll need two things:
  • An SD card reader supporting SDXC (or stating explicitly that it can read 64 GB SD cards);
  • A data recovery tool that supports exFAT;
Not all data recovery tools can support exFAT because of the restrictive licensing model employed by Microsoft. Even if a tool advertises support for "all types of memory cards", it may or may not support exFAT. One of the tools known to support SDXC memory cards and exFAT file systems is Hetman Partition Recovery.
But I've Just Bought a 64 GB SDHC Card!
Sigh. This chapter is probably the most disturbing part of this article. Every other week, we receive an email from a customer describing a typical situation. Because there are so many reports, and because they all describe the same thing, let me just summarize it below.
A guy buys a 64 GB SD card for a price that's significantly below the market. When the memory card arrives, he tests it in his computer, discovering 64 gigabytes of usable capacity. Suspecting that 64 GB of flash memory for under $5 could be a scam, the guy tests the card by writing some data. The writes are extremely slow (3-7 MB/s), so testing the entire capacity would literally take the whole day. He writes some 1-4 GB of data and reads it back. All seems fine, so the guy formats the card and puts it into a phone, MP3 player, digital camera, or whatever portable device he bought it for.
Day after day, week after week the card is filling up with data. Pictures, music and videos are saved onto that memory card. 8 gigs, 16 gigs, 32 gigs, 64 gigs - the writes keep going, the memory card seems to be holding well. Then all of a sudden a photo won't show in a viewer, an MP3 file won't play, a video won't show up. The guy takes the card out and connects it to a PC in an attempt to save the rest of the data. But... oops! There are no photos, music or videos on that card, just garbage.
It is this moment the guy seeks for help and writes us an email. Sadly, in situations such as the one I described our hands are tied: that memory card was a fake. In fact, the "deal" advertises a 64 GB micro SD card for only $4.79. Yes, it's under five bucks for a 64 GB memory card. The description is Pidgin English and reads something like this: "New 64 GB Class 10 Micro SD HC Memory Card with Adapter Fast USA Shipping Dependable memory card for your favorite photos, videos, apps, and games Easily transfer files between phone, tablet and camera" blah, blah, blah.
Remember: if it seems too good to be true, it's probably not true. See that "Micro SD HC" designation? It's a dead giveaway. You can't buy 64 gigs of memory for $5. And, THERE ARE NO 64 GB SDHC CARDS, period. The SD standard dictates that all SD cards with capacities higher than 32 GB are made to conform to the newer SDXC standard. If you buy this card, you won't be getting anything but a fake.
Ditto. Do not buy these. Remember how the packaging looks, and ignore deals that seem too good to be true.
SDXC Recovering 64GB and 128GB Memory Cards Hetman Software
on Jun 06, 2016 | Hetman Partition Recovery - Recover...
My 128 GB microSD card is restricted to 16 MB after formating it.
Try to format on a PC and make sure you select NTFS and not FAT32.
Hth.
Apr 21, 2017 | Cameras
What type sandisk mirco sd cards work?
You didn't buy a microSD card, you bought a microSDXC card.
The Eclipse 180 works with microSD cards (2GB or smaller) and microSDHC cards (32GB or smaller). It does not work with microSDXC cards.
Jul 26, 2014 | Mach Speed Eclipse 180 MP3 Player
Microsd card won't read
You need to use a microSD card, not a microSDHC card. microSD cards max out at 2GB, anything larger is a microSDHC.
The 1390t works with microSD cards. Your 8GB card is actually a microSDHC card. While it fits into the slot, it will not work in older devices.
Feb 09, 2012 | Garmin nuvi 1390T Car GPS Receiver
Kingston Data Traveler 2.0 64 GB USB - file system corrupted - need to work on windows XP- Upon formatting the pen drive It shows that it has become a raw drive - wat is the file format for the USB to work...
Theoretically, you can't format a more than 32 GB drive with FAT/FAT32 file system. In your case you have to choose the NTFS file system to format your 64 GB USB flash drive. However, if you really need to format it with FAT32, you got to use the command line or a third party tool. Hope this is going to help you.
Apr 06, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How i fix the erro on my sandsk 32gb but now i can format only have 8.00mb
If you have a USB card reader you can open the card in Windows and tell it to format FAT32. That should give you a full format.
Mar 05, 2011 | SanDisk 8GB microSD High Capacity...
WIndows is saying it cant format my microsSD memory card
  • Navigate back to "My Computer." Right-click on the SD card drive and select the '"format" option.
  • Leave the "capacity" option at what it is. Under the "file system" menu, select the file system that you wish to use with the MicroSD card (FAT or FAT32). Leave "allocation unit size" alone, and rename the card's name to anything you desire in the next menu. Do not select the "quick format" option, as this will not fully clear the MicroSD card. Once you have filled out all these options, select the "start" button at the bottom of the window. Wait for the formatting process to complete.
  • Now copy back any of the files that you copied to your hard drive, and your card is now clear and ready for new devices.
  • Oct 01, 2010 | SanDisk 2GB microSD Memory Card
    What is the most capacity of Micro SD that suport of that cellphone!
    The SDA announced the microSD format at CTIA Wireless 2005 on March 14, 2005, and approval of the final microSD specification was announced on July 13, 2005. At launch, the microSD format was available in capacities of 32, 64, and 128 MB. SanDisk introduced a 2 GB microSD card in July of 2006, initially priced at 99 USD. Since then, prices for flash memory devices have fallen dramatically. The same 2 GB card as of April 2009 can be found for as little as 12 USD at department stores, and as of May 2009 for as little as 6 USD at online electronics stores. At present date Jan 2010 a 16 GB micro SD card class 2 comes for about $40 and a 4 GB class 2 micro SD card comes for about $8.
    please rate my answer as helpful. thanks. Joe
    Feb 23, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
    How do u format sandisk microsd 2gb and microsdhc 4gb disks
    You can only form sd Hc if your card reader is approved for SDHC use. It should tell you that on the outside of the card reader or in the documentation of the card reader.
    If your drive isn't formatting 2gb, it could be that the driver was designed prior to 2gb cards being released. You could look for a new driver or replace it with a card reader that supports SD HC use as will as a 2 gb SD drive.
    Nov 12, 2008 | SanDisk 2GB microSD Memory Card
    Electronics - Others Logo
    388 people viewed this question
    Top Electronics - Others Experts
    Marvin
    Marvin
    Tom Chichester
    Are you an Electronics - Other Expert? Answer questions, earn points and help others
