Question about Blomberg Refrigerators
Take out bulb.
Posted on Sep 21, 2018
There is no bulb genius!
Then how does it light up?
If I knew how, would I asked the question?
It’s LED lights built in.
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out. IT costs $200/yr. They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit. He said that a new motherboard and the labor alone was going to make it $498. Anyway, he had ordered a new motherboard. Apparently the motherboard wasn't working. It is located in the back bottom left side of the refrigerator behind the panel. There is a compartment on the lefthand side that slides out and houses the motherboard. He put that in and also had to fix the fan that is in the back of the freezer. That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all. So at least take a look at the fan in the freezer. Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover. Maybe that's the problem with your refrigerator, the fan. Hope that's all it is. Good luck!
Posted on Jun 25, 2008
If this appliance is new, I would suggest to contact the vendor or manufacturer and ask them for in home service.
It could be the thermostat that might be not working properly or not set properly.
Check the user manual for more info on the thermostat settings.
Posted on Jul 08, 2008
SOURCE: refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Posted on Oct 13, 2008
SOURCE: Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Posted on Nov 05, 2008
SOURCE: Maytag model # mbf2254hew bottom freezer refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
Jul 11, 2018 | Blomberg Refrigerators
Feb 11, 2015 | Blomberg Refrigerators
May 03, 2014 | LG Refrigerators
Feb 24, 2013 | LG LSC26905TT Side by Side Refrigerator
Dec 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Mar 31, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Jan 04, 2009 | Frigidaire FRT21P5A Top Freezer...
Aug 19, 2008 | Miele KFN8762SDED Bottom Freezer...
Aug 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
128 people viewed this question
