SOURCE: 1999 Ford Windstar will not start after tune up......help
HI !!! ome times the battery looks new but try to check the power it shoulbe 12.5. -2) check firs the gas pump fuse .if is ok open the o turn the ingicion swich if you hear some bbuzzzzzz noise the fuel pump is working. before you try to do thi get some gas line antifres and put this on the tank.o maybe when you replace all the parts you have mencion you forgot to connect the ingntion coil
SOURCE: drain radiator
How easy is it to remove lower rad hose? I've reverted to that more than once rather than fight with some of those drain plugs & their neat locations.
SOURCE: codep1309 1999 windstar
P1309 is a code that occurs when the PCM diables the misfire counter due to com. issues between cam pos sensor and crank sensor. generally a bad cam sensor
SOURCE: 1999 Ford Windstar-Will Turn over but won't start?
fuel pressure regulator could hav failed-located by engine or the ignition module may not be workin-by dist area try not to be a parts replacer-buy a repair book
SOURCE: how do i fix p1518 code on 1999 ford windstar?
P1518 - Intake Manifold Runner Control Malfunction (Stuck Open) The
IMRC system is monitored for failure during continuous, key ON engine
OFF or key ON engine running self-test.
The test fails when the signal
on the monitor pin is less than an expected calibrated range at closed
throttle.
* IMRC monitor signal circuit shorted to PWR GND or SIG RTN
* Damaged IMRC actuator
* Damaged PCM
Hope this info helps
