Question about GE CleanSteel GSL25JFTBS
Water/ice dispenser My water/ice dispenser does not dispense water or ice.The problem started with the ice but now has progressed to the water.The freezer still makes ice. The water has just stopped working altogther, it used to be only when one tried to get ice that the water would not work but now it doesn't work at all.Also the light kind of like flickers as well
Posted by cats5 on
  • nick40 Feb 21, 2008
    The ice maker and dispenser works fine. The water dispenser stopped working out of nowhere a couple of days ago. I checked the water lines to see if they were frozen but they are not.
  • Shoshee Jun 12, 2008
    My Kenmore Elite side by side model 52693100 makes ice but will not dispense it. Not frozen, the shaft that would run the ice down does not turn. Then one week later, it will not dispense the water either. Help!
Anonymous
I just found out my ice dispenser was not working either, however my water is; I took the ice catch tray out and then removed the shelving unit that covers this tray. The water dispensing from the back, to form the ice, was froze. I too had the flashing green light; I assume that if you did not catch the freze-up that it would eventually prevent water dispensing to the water dispenser. I allowed it to thaw and adjusted the temperature setting for the freezer.
Posted on Jul 30, 2009
Anonymous
I do not have any wires below the doors....any thoughts on that
Posted on Sep 08, 2008
Anonymous
  • 213 Answers
If you take the kick plate off below the doors, youll see a small wire harness on the left hand side. youll see a plastic conection where the wires come together. one or more wires are broken. its a pretty common problem with ge. if you cut the conector off and use butt conectors to reconnect the wire matching the colors you wont have the problem anu more
Posted on Nov 26, 2007
1 Related Answer
Anonymous
  • 120 Answers
SOURCE: water/ice dispenser
hi george i will try to help firts i want you to try this. pull off the bottom grill or kick plate and make sure that the wire harness is connected and not loose they get loose a lot on this brand. now if they are look at the water line conector but the bottom hinge disconect it for there and close the door and ask for wtr at the lever if you get water the you have frozen line inside door if no water then check the resevour inside the refrigerator and make sure is not frozen if it is ok then if you model hasa mother board at the back repl when both ice and wtr go out that is usually the problem i see it every day ok take the model number with when you buy the part sothey can give the right board ok.
Posted on Oct 15, 2008
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ice maker makes ice but freezes before it can be dispensed so the dispenser is always clogged with frozen ice. Cleaned out the ice maker and started over but same results. The temp is set at 38 for the...
Hi, The freezer should be "0", the possible clogging you have could be a leaking water valve or an over filling ice maker. I would have the ice maker checked for volume of water dispenser during harvest, should be 5.5 oz. (2/3 cup), if more the 6 oz. the ice maker is bad. If fails to stop filling or leaks/drips, replace the water valve behind the unit.
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 27, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
GE refrig/freezer dispenser makes ice, but no dispensing of water
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Oct 05, 2009 | GE Refrigerators
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Water/ice dispenser
Oct 15, 2008 | GE GSS20IEP Side by Side Refrigerator
Dispenser
Sounds like a control fault on the microswitch to activate the ice and water line. Access to this is immediately behind the ice dispenser section (just above) on the freezer door. Normal access is two screws located behind the removal drip tray section. Either that or the control board for the ice dispenser as you are not getting water as well. Before taking this section apart though you should hear a buzzing sound when you activate the chilled water, if you do then you may have a water supply problem. Hope this helps.
Mar 13, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
GE CleanSteel GSL25JFTBS Logo
757 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
