Windows 10 does not like this thing.
ask Ms.com why.
only they have drivers for imported things like this if at all.
ask here
https://answers.microsoft.com/en-us/
or ask the maker or seller for help/
https://www.zagg.com/us/en_us/audio
SOURCE: no speaker sound (HP Pavilion dv6000)
there a loss connection in the speaker of your system. locate the loss connection and fix it. if hard for you fix then you should call the technician to fixed for you ..or either use external speaker so that you can hear sounds without using headset.
SOURCE: I'd like to connect my HP laptop to Yamaha 663 receiver
Connect your S-video output from the computer to an empty S-video input on the receiver. Connect your speaker output from computer to analog audio input on the receiver using a 1/8" stereo connector to RCA patch cable. You may have to set your computer to output video to the S-video jack, consult your HP documentation for instructions.
SOURCE: New HP monitor connected to Dell laptop (Windows
1. check whether u have inserted the audio cable in the right port (Headphone Port)!
2.also check the audio settings of headphone port (volume,channels,etc.)
Testimonial: "Great! The audio cable wasn't plugged into the "head phones" jack. My bad :( Now I am trying to get more volume out of the speakers in monitor?"
SOURCE: Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
SOURCE: My N70 mobile is showing headset symbol even when
To solve the Nokia N70 headset problem is simple. You don't need any hardware repair just follow the instruction on this webpage:
http://www.4u3.biz/Articles/electronics/mobile-phones/nokia-n70-how-to-remove-the-headset-enhancement-symbol.html
WORKS LIKE A DREAM!!
