Question about Building Materials
I need a new remote for two NED 8700 in my garage.
Posted by Valgeir Asgeirsson on
mehan
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Chamberlain Universal. Read the package to be sure before purchase.
Posted on Apr 19, 2019
I have an NED 8700 garage door opener. When I purchased the house it didn't come with remotes. I have purchased a universal remote. I can't seem to locate the learn/smart button.
Here is a rather silly video that could assist you, although it isn't actually for your actual door, all such doors have a similar set-up.
http://precisiondoor.net/videos/program-liftmaster-remote
Jan 03, 2018 | Building Materials
Remote control does not work
Good evening.
It is irritating when the remote doesn't work or is lost. You can download a remote in your phone and use the phone as a remote.
Before that check the batteries. It has been known to happen that a new battery is needed. Try that first before you try to get one from the internet it buy one in a shop.
kolbrun
Mar 09, 2016 | Mintek DVA-8700 System
NED 8700 smart button location
a marantec ned8700 has no smart button you have to open the remote n remove the battery then connect the programming 3-prong cable to the terminal on the side of the remote (under the rubber cover) the with a flat screwdriver short out 2 of the prongs one must be the center prong. press and hold the button on the remote that is active, in 2 seconds code will change. elease the button after the light illiminates continuously then remove the programming cable/prongs and replace battery n cover then press n release p button on machine till only 7 lights up take remote hold it 3'' away from button and press button on remote to program for 10 secs release then push p button on machine once, 8 will light up and your set to go
Nov 04, 2012 | Genie Company Home Security
I ned the replasment for Craftsman model 139655000 ?
That model is so old there are no parts available. You need a new door opener.
May 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote key will not open or close to car
ok, stab in the dark. turn off your radioand disconnect you battery negative for five minutes, then reconnect.didn't work, ok. Turn your ignition awitch on and of 3 times... Hopefully these two methods of reset for ecu worked. Good Luck, Ned
Sep 16, 2009 | 1999 Audi A4
Remote will not work when the lights are on
Does unit work from wall button during the two minutes. I;d say this is certainly odd. Might need new board.
Apr 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door keypad & remote
You need to sync both. I have a LiftMaster. If you want to change the code on your keypad you need to open up the garage door motor compartment where the light is (mine is in the back). Press the learn button, within 30 seconds enter the new code on your keypad and hold down the enter button for several seconds until the light on the opener blinks to tell you it has learned the code. Test the new code to see if it works. If the new keypad code works, then try the remote. My remote will not work after I reprogram the keypad. If the remote does not work (check battery) then climb back up the ladder and press the learn button on the garage door motor again, press the remote button and hold down until the light blinks again and the opener has learned the new code. This process works when I need to sync my remote and keypad. Good luck, I hope this helps.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
406 people viewed this question
Top Building Materials Experts
Tom Chichester
ray gallant
robert
Are you a Building Material Expert? Answer questions, earn points and help others
