Vtech CS5121 Cordless Phone Logo
Posted on Aug 03, 2009
Phones display power failure or out of range when turned on.
Phones won't get dial tone when turned on and display "power failure or out of range" message. Although, the phones can be paged by the base so I know they are in range. I also know the phones are charged.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2352
Points
Cordless phone reads out of range power filure
Anonymous
Level 1:
New Friend:
  • Posted on Dec 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2352
Points
My Binatone Idect Edge single DECT has no dial tone, just a buzz. The display is working, but I cannot ring out, or receive calls.
Did you connect another phone to make sure that wiring is not a problem? Because you visually check it, doesn't mean that there is not a problem.
1helpful
Call forward will not turn off, have tried *74 & *73 , have rebooted and turned off then on, call divert symbol still on and phone calls still diverted.
To set Unconditional Call Forward ON Dial "*72" for a dial tone. Dial the forwarding number followed by "#". Wait for dial tone. LCD will display "Call FWD Activated"
To Cancel Unconditional Call Forward: dial "*73" and get the dial tone, then hang up. LCD will display "Call FWD Activated
but, since you have tried those two, it could be that there might still be a different type of call forward option that is still ON, on your phone like Busy Call Forward and Delayed Call Forward 1. To Cancel Busy Call Forward: dial "*91". Wait for dial tone. Hang up.
2.To Cancel Delayed Call Forward: Dial "*93" for a dial tone, then hang up.
Let me provide you a link to the website which I used as a reference for your future reference.
http://www.grandstream.com/user_manuals/GXP_User_Manual.pdf
Handset displays "Line in Use" no dialing tone and
I can't get dial tone either. Let me know if you find a solution please.
No dial tone,still ringing with incoming calls,display reading power failure and out of range
Sorry, this is not a solution, but I have the exact same problem! Did you ever figure it out??
15helpful
Samsung SGH D900I- cannot turnoff keypad sound
The steps are outlined in the article below:
D900 FAQ – How do I disable or mute the keypad tone on my SGH-D900? admin March 6, 2009 --> Note: In order to disable the keypad tone, the Dialing Display Font Type must first be set to “Normal”
To change the dialing display font type follow the steps below:
  1. From the standby screen, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Display Settings (3)
  4. Select Dialing Display (6)
  5. Select Font Type (1)
  6. Highlight either Normal or Theme, using the navigation keys
  7. Press the left soft key to Save the Dialing Display Font Type setting
To turn off the keypad tone follow the steps below:
  3. Select Sound Settings (4)
  4. Select Keypad Tone (2)
  5. Highlight Off, using the up navigation key
  6. Press the left soft key to Save the Keypad Tone setting
1helpful
We had a thunderstorm and a transformer was struck by lightening. I have no dial tone. Do I need another AC Adaptor. The display screen is blank. My other telephone worked ok when I plugged it up....
What all you need can be decided upon after eliminating the faulty items one by one. First the AC adapter. Check with another device if the adapter is functional. Or if you have a multimeter. Next the phone, try another adapter. Where from? Read the specs printed on the adapter. It will tell you the Input and output voltages. Then it also tells you about the frequency. Then the wattage. If all of them match or come close you can use it. Trip to the store is warranted. Thunderstorms and lightenings generally do not leave anything intact. So, I hope your phone is intact. Adapter can be replaced easily.
3answers
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
