Question about Necchi Sewing Machines
I have necchi 300 Sofia need to put the plate back on but it keeps sticking out I was only cleaning it out
Posted by Dee Morris on
1 Related Answer
99rannellis
R.A. Ellis
  • 12731 Answers
SOURCE: I cannot load bobbin into my Necchi Sofia 300. ??
Perhaps this will help:
How to Thread Necchi Sewing Machine
Posted on Apr 08, 2018
I am in need of a Necchi 538/539 needle plate as shown in picture.
Fixya is unable to suggest a source of a Necchi needle plate other than possibly Necchi.
May 16, 2018 | Necchi Sewing Machines
I need a manual for Necchi Sofia 300 sewing machine please
Search for:
Make Model manual
you may be lucky to find one online.
Feb 13, 2018 | Necchi Sewing Machines
My Necchi Sofia 300. When winding bobbin the needle doesn't disengage and the matching makes a dreadful grinding noise as it winds the bobbin
Try putting a small drop of oil on the the metal shaft of the bobbin winder if it is not moving freely. The grinding noise implicates the winder tire may be ground from the locked winder shaft. The needle not disengaging requires oil in the shaft bushing. On this machine it appears you would have to remove the covers to access the appropriate areas.
Dec 05, 2016 | Necchi Sewing Machines
I have a metal spernova child's sewing machine. I have threaded it, but it keeps jamming up. It doesn't create the chain stitch on the fabric. What am I doing wrong??
put in a new needle
clean under needle plate for loose threads or lint
clean bobbin area for same
check the top tension to make sure it correct for the fabric
make sure its threaded correctly top & bobbin
make sure the top thread does not come off the thread take up lever
Aug 03, 2011 | Necchi Sewing Machines
How do you change the bulb in the necchi omega 6018
there is a door on the left it's called a lamp cover door or a face plate- on my mechanical necchi there are hinges behind the door at the back,,gently pull open the door & the bulb will be accessible
on my other necchi there is a cap in the middle of the door with a hidden screw, gently pry the cap out & take out the screw & there is the bulb,,just reverse the process to put the door back on
Dec 08, 2010 | Necchi 6018 Mechanical Sewing Machine
I don't really have a problem, but cleaning. I would like to clean my Necchi Model 3355 myself, but don't know where to start. Help
I also have 2 necchi sewing machines,, here's what I do
keep a check on the needle to make sure it not bent,blunt
clean under the needle plate where the feed dogs are for lint--if you sew alot every week--if once in awhile once a month
also clean the bobbin area for lint or loose threads
keep a cover on the machine to keep out dust
Nov 26, 2010 | Necchi Sewing Machines
Sewing Machines Logo
37 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
