Question about Sport & Outdoor - Others
Need pole # alignment instructions for northpoint 10.5 x 10.5 canapy
Posted by Joe Black on
Tom Chichester
    Top Expert:
  • Sport & Outd... Master
  • 55,379 Answers
Request the instructions directly from Northpoint.
Posted on Sep 20, 2018
I have a North Point screen tent and I would like to replace the poles. Anyone know where I could order them from?
Hello, Amy -
Apparently Northpoint Adventure Gear was a private label sold by Sports Authority stores. Sports Authority filed for bankruptcy in 2016 and ceased doing business. For a while, after Sports Authority ceased doing business, information on its website directed those interested to Dick's Sporting Goods.
I only find a tent pole repair kit being sold by Dick's Sporting Goods, currently, in stores only:
https://www.dickssportinggoods.com/p/coghlans-tent-pole-repair-kit-16cghufbrglsstntpcat/16cghufbrglsstntpcat?
If you still have the poles for your Northpoint tent, do not toss them out, just yet.
I have seen a variety of replacement tent poles for sale through Amazon. You MAY be fortunate enough to find replacement tent poles which will work with your Northpoint tent for sale there.
Best wishes.
May 12, 2018 | Sport & Outdoor - Others
I need assembly instruction for 8 person cabin dome tent with screen house
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Oct 23, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
    I need pitching instructions for a Great Outdoors Executive 320 tent. Can anybody help please?
    I recently borrowed a similar tent and this forum was all the instructions I had (so thanks, they helped). I have since found the instructions, scanned them and made them available to others (to view/print/download) at https://docs.google.com/open?id=0B1SdA-vKLONwZ05vTGZKdF9BTzQ
    Paul.
    Dec 23, 2010 | Sport & Outdoor - Others
    I have a 10x13 northpoint adventure gear canopy with no instructions. Can you tell me where I could find them online?
    This is for Northpoint 13' x 10' Screen House Style# TC-S130A-03.
    http://s218.photobucket.com/user/Pokeytoesmomma/media/Screenroomtent2.jpg.html?sort=3&o=0
    http://s218.photobucket.com/user/Pokeytoesmomma/media/Screenroomtent1.jpg.html?sort=3&o=1
    Sep 06, 2010 | Garden
    We need help with setting up coleman 13x9 forrester tent
    General tent setup instructions:
    thread assembled poles through sleeves
    connect one end of poles into tent corners
    1 by 1 connect the other end of the pole, work front to back and the tent should assemble quite easy.
    Oct 02, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
    Coleman salt lake tent 9 man no instructions please help?
    the instructions are useless anyway. you put the red poles through the 2 side bedrooms. the black rods and the black poles with the bends in join together and go diagonally through the middle of the tent. the yellow rods join together with the black poles with the yellow tape round the ends and u fit these from the inside of the front and back entrance then when the tent is up you just hook the bedrooms in. hope this was usefull
    May 23, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
    Instruction to put up a Coleman Rock Springs 4 Tent please?
    Wow, thats a monster tent. I'll get you most of the way there, but I may miss a thing or two
    Lay it down, stretch it out and peg it. That will save you a ton of time.
    Next, find the four longest poles. These are the supports. Two on each side of the door, crossing diagonally to the rear. Put one end of the poles in the holes and bend until you can get the other end in. These poles should slide through sleeves in the tent. Once these are up, the rest are "extras." The tent has hooks to hold the poles to the tent.
    You have two poles of equal lengths for the side windows. Again, route them thru a sleeve, bending them into the holes on either side of the windows. I can't tell, but it looks like you have a pole system for the front door too. Somehow these poles go next to the main support poles and meet up under the rain cover.
    Next, lay the rain cover on top of the tent. It should connect by bungies to the bottom of the pole support holes. There might be a pole or two under the rain cover, but above the tent for support. If so. look for a small pouch that a pole could slide into on the bottom side of the rain cover. You'll run the pole from the pouch to another pouch (all under the rain cover).
    Don't worry about strings or extra poles. These are for high wind. Pegging the tent down is good enough.
    Good luck
    May 22, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
    Where can i get assembly instructions for great outdoor tent
    You can get instructions for Great outdoor tents if their not too old from Great Outdoors Hastings
    Dec 22, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
    Sport & Outdoor - Others Logo
    239 people viewed this question
    Top Sport & Outdoor - Others Experts
    Marvin
    Marvin
    Tom Chichester
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
