Question about Camping, Backpacking & Hiking
How do you replace the spring on a d cell flashlight
Posted by Merle Halsema on
Kris Blidnaut
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Each brand of flashlight would have different mounting methods for their springs & i presume your main issue is to remove the old (& probably rusted/acid-corroded) spring...
without a photo of your specific spring's mounting, the best advice would be to:
* use a pair of side'cutters to cut off as much of the old spring as possible, but leave the mounting point intact. (with at least 7mm of the old spring also left in-place)
* then bend that remaining piece into a tight loop.(with needle'nose pliers or the side'cutter)
* feed the bottom end of your new spring through the tight loop you've created from the old spring & rotate the new spring until it is firmly seated between the old spring & the torch's casing.
>> if the old spring is completely trashed - your easiest solution would be to replace the torch unless you have skills in re-construction... (to securely Mount the new spring) ~ but if you had those kinds of skills, i doubt you'd have asked for help in the 1st place... :-p
Posted on Oct 02, 2018
Why does my 2d mag flash light stay dim
Check for corrosion at the bulb, or the spring or the switch. This happens sometimes when batteries leak internally.
Oct 20, 2014 | Other MAG-2D - Maglite Small Head 2 D-Cell...
How do I replace the led in a 2w d cell maglite
Unscrew the top half of the flash light and pull the bulb straight up, and it's out,
Not to mention there's usually a spare bulb in the base of the flashlight under the spring in a piece of foam. unless someone used it already,
Line up the two pins and slide it back into the to pin holes on top and with the bottom of the flashlight back on with battery's try the on off switch and make sure it lights up and not have dead battery's, if it lights up throw away the old led and screw on the top of flashlight,
If it still don't light check for new battery's.
Oct 03, 2014 | MagLite Mag Instrument Mag Lite 2 "D"...
Fullcharged new battery, light is green on charger, brandnew never used WF502B and nothing, no light clicked it severl times.
Try unscrewing the flashlight head from the flashlight body and removing the LED lamp assembly. It is integrated with the reflector which can also be unscrewed from the lamp assembly if necessary. The lamp assembly makes contact through two springs that make contact with the flashlight body and it is possible it was not assembled correctly causing one of the springs to be distorted and not make contact. Failing that, the LED emitter assembly might be defective.
Dec 15, 2011 | UltraFire WF502B
What is the alignment of the batteries in a 3d cell?
put the first one in positive side toward the light,, and the rest go in the same way, make sure the spring is attached to the base and screw it on, the positive side of the battery is the side with the bump on the end,, if it doesn't work after that ,, in the end cap of the flashlight you should have a extra bulb,, replace that and try it ,, be sure to put the spring back on the end cap
Aug 26, 2011 | MagLite Mag Instrument Mag Lite 2 "D"...
Witch way do i put the batterys in?
hello paulcamyre the direction of the batteries is dependant on which end of the flash light has the spring. most flashlights are maufactered to were the batteries usually go in positive side toward the light bulb. the end of the flash light that has a spring is the side the batteries negative end should be pointing
Nov 16, 2010 | Princeton Tec Impact XL Flashlight
We changed the battery pack and the bulb and it wont come on so the switch is prolly defective where do we find how to repair the flash light
Alot of maglites are problematic with symptoms like this... I have found that the culprit many times is the screw cap on the bottom of the flashlight.
The elecrtrical connection needed between the spring in the end cap, the threads on the cap and the threads in the barrel of the flashlight...
Make sure you twist your spring a bit..the dissimilar metals can actually corrode between the spring and the cap... Then spin the threads a little... Then try the flashlight again...
This procedure may save yourself replacing a switch..
Apr 29, 2010 | MagLite Rechargeable Flashlight System
How do you get the spare bulb out?
1st take off the spring at the bottom to expose the lamp. Then pull it out and replace the burnt out one.
Dec 25, 2009 | MagLite Mag Instrument Mag Lite 2 "D"...
How do you change the bulb in a mini maglite?
Carefully.....
Check in the base of the torch and you will see the spare bulb. you need to pull the spring out to get at it.
Next unscrew the top off the torch to expose the bulb.
The bulb is easily removed by gently pulling straight out. Replace the new bulb in the same way, lining the two pins up with the holes (doesn't matter which way round) and wipe the bulb clean of any finger grease etc.
Screw the top back on and replace the spring in the base before screwing the base back on..
Replacement bulbs, and all other parts for that matter, are easily sourced at any good outdoor store that stocks MAG.
Hope this helps..
Jul 05, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Keeps turning itself off when adjusting beam
It sounds like the spring in the tail cap may be depressed which would cause intermittent contact with the negative end of the Batt. Shake the flashlight vigorously, you should NOT hear ANY noise. If you DO, take the end cap off and pull on the spring, you are trying to stretch it out a bit, replace the cap and shake it again. Go through these steps until it is QUIET when you shake it.
Also make sure there's NO CORROSION at the Positive and Negative ends of the contacts.
Maglites are pretty user friendly and the best light money can buy. I have the rechargeable model which I carried for 21 years during my tour in law enforcement.
Anyway, if it still refuses to work properly, go to; www.maglite.com they are based in California. They will help you get it going. Good luck. :)
Apr 12, 2009 | MagLite 3 Cell D Blue Flashlight S3D116
Camping, Backpacking & Hiking Logo
345 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
Kardoc
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
