Question about Golf
2002 club car has intermittent spark if i grown out spark i will get spark back
Posted by ed altwies on
2 Related Answers
golfcartman
  • 34 Answers
SOURCE: club car golf cart intermittent no spark
What you have is a bad ignitor. It is a small part located behind the RPM limiter. Getting to it is a little tricky but I will try to explain. On the front of the motor, you will find 2 10mm bolts holding a black object that is the RPM limiter. Take these two bolts out and you will find the silver part behind the black box. It will have one wire running to it. The reason it is intermittent, is that heat from the engine builds up and the heat causes it to be bad. When it cools down, it will go to running again. The part runs about $50-$70 . Replace and make sure the connection fits snugly and that the wire that was under one of the bolts goes back on.
Posted on Apr 22, 2010
sulavaca
Jamie Alton
  • 1007 Answers
SOURCE: cannot locate fuse on 2002 club car/turn signals & brake lights do not work
Just pull all fuses one by one and inspect them in turn.
Posted on Nov 19, 2012
Why does ammeter intermittently "peg out" after driving for awhile?
Replace the autonator sounds like it has a week resister in it and is letting it over charge. Its easy to replace.
Jan 31, 2016 | 2002 Dodge Dakota Club Cab
My Renault scenic 2002 2.0 has a stop warning light on the dash. the car has no spark and it turns intermittently. what could be the problem. please help
Run codes for a clue to what is wrong. Turns intermittently I suppose means sometimes it cranks over and other times not, but never starts. That would likely be bad starter or solenoid. No spark can be bad crank/cam sensor, bad coil or module, bad fuel pressure/pump, bad coolant temp sensor, etc.
Jan 23, 2015 | Renault Cars & Trucks
Wiper control problem.
Lift up once: results in one swipe
Pull down to position 1: results in intermittent wiping
Pull down to position 2: results in constant slow wiping
Pull down to position 3: results in constant fast wiping
Jul 22, 2012 | 2002 Dodge Dakota Club Cab
My 4.7L dakota has a cylinder not firing. Compression checked out ok. Can you suggest a possible cause?
This can only be a bad spark plug wire, a bad spark plug or a bad distributor....start with the wire....switch one of the wires out and see if the problem moves with the wire. do the same with the spark plug and if this does not solve the problem, you issue is with the distributor. Good luck
Feb 07, 2011 | 2002 Dodge Dakota Club Cab
Club car golf cart intermittent no spark
Sep 20, 2009 | 2002 Chevrolet Avalanche
2002 Mercury Sable-shakes with acceleration
You describe this as an acceleration problem however, if the car does throw a check engine light it should be recorded in system memory so it can be pulled by scanning with and OBDII scanner. It sounds as if the car is being starved for fuel on acceleration. Check the fuel lines for kinks as well as check the fuel pressure. The problem could be a faulty fuel pump that has yet to completely die.
May 21, 2009 | 2002 Mercury Sable
Rear Lights and Wiper Problem
any time you have a crazy electrical problem always check ground connections
Jul 23, 2008 | 2002 Dodge Dakota Club Cab
Golf Logo
315 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
