Question about Krups Coffee Makers & Espresso Machines
Error 9 on a Krups EA8000 Expresso . The contacts on the thermobloc are OK
Posted by Cornelis Ivo on
Ross Keen
  • Krups Master
  • 1,364 Answers
Error 9 is only related to the NTC on the front of the thermobloc. That's the wires, terminals or the resistor on the NTC that changes value with heat.
Posted on Sep 25, 2018
2 Related Answers
Anonymous
  • 5 Answers
SOURCE: Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Posted on Aug 07, 2009
archiplast
  • 9 Answers
SOURCE: my krups ea8000 give me
your have wrong position of distributor pls check. God Bless
Joseph
Posted on Aug 31, 2012
Error Code 9 on a Krups EA8000 Expresso machine
The heat sensor on the boiler is not detecting any temperature change. It could be a wire or terminal off. The sensor is right at the front of the boiler. If the sensor is faulty it means a new boiler because it's stuck on in the factory.
Sep 19, 2018 | Krups Coffee Makers & Espresso Machines
Expresso machine screw on lid leaks steam
The valve in the lid is faulty, it will eventually fail completely. The correct lid can be ordered from your local Krups service agent. Be prepared for disappointment though as many of them are now obsolete. You will need to give the agent the model number, it's normally on a sticker on under the base.
Jul 03, 2018 | Krups Coffee Makers & Espresso Machines
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Feb 11, 2014 | Coffee Makers & Espresso Machines
My krups ea8000 give me error 1
Joseph
Jan 13, 2011 | Krups Small Appliances Espresso Machine
Jun 06, 2009 | Krups XP4030 Espresso Machine
Coffee Makers & Espresso Machines Logo
176 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
