Coffee Makers & Espresso Machines Logo
C
Cornelis Ivo Posted on Sep 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error Code 9 on a Krups EA8000 Expresso machine
Ross Keen
Level 3:
  • Krups Master 1,365 Answers
  • Posted on Oct 02, 2018
Ross Keen
Krups Master
Level 3:
Answers
1365
Questions
0
Helped
582654
Points
2445
The heat sensor on the boiler is not detecting any temperature change. It could be a wire or terminal off. The sensor is right at the front of the boiler. If the sensor is faulty it means a new boiler because it's stuck on in the factory.
1 Related Answer
Anonymous
  • 5 Answers
  • Posted on Aug 07, 2009
SOURCE: Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Error 9 on a Krups EA8000 Expresso . The contacts on the thermobloc are OK
Error 9 is only related to the NTC on the front of the thermobloc. That's the wires, terminals or the resistor on the NTC that changes value with heat.
Expresso machine screw on lid leaks steam
The valve in the lid is faulty, it will eventually fail completely. The correct lid can be ordered from your local Krups service agent. Be prepared for disappointment though as many of them are now obsolete. You will need to give the agent the model number, it's normally on a sticker on under the base.
1helpful
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
1helpful
My krups ea8000 give me error 1
your have wrong position of distributor pls check. God Bless
Joseph
25helpful
3answers
16helpful
2answers
Krups model 865 Coffe and Expresso maker manual
I NEED A MANUAL FOR A 865 KRUPS COFFEE AND EXPRESSO MACHINE, I DID NOT GET ONE
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
