Question about Jensen Audio Players & Recorders
SOURCE: Ipod internet
well! man it`s that your ipod`s firmware or software has some corruption.i don`t know how it came but you can fix it by upgrading your ipod`s firmware using itunes and clicking on check for firmware or upgrade firmware.
even i do have ipod touch and i love it.
take care.
Posted on Jun 13, 2009
SOURCE: ps3 wont load game
I had a similar problem. My PS3 did not start the disk based games.
Those disk based games were not visible in the game menu. I did not
have problems with the normal movie DVDs or Movie Blu Rays. Those were
working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After
PS3 has executed the DB rebuilding operation, the disc games will be
visible again in the menu and are starting automatically when inserted
to PS3.
Posted on Jun 18, 2009
SOURCE: Songs shown loaded on the iPod on my computer, but iPod is empty
Well first I have a question that may seem silly. Are you using iTunes? If not you will need to start doing so. Apple designs the iPod to only work properly with itunes. There for many other media players may sync the ipod for a time but eventually it will stop working.
If so you may want to restore the iPod then attempt to re-sync everything. If this does not work you most likely have a hardware issue.
If any of this seems unclear or you need advice on how to perform these tasks please do let me know. :-)
Posted on Jan 09, 2010
Testimonial: "That worked - thank you."
SOURCE: when you turn the comuter on, it just shows the
--SAFE BOOT MODE--
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X StartupItems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
This should help get your iMac G4 back up
and running.
Regards,
Mactechtrainer
Posted on Jan 30, 2010
Testimonial: "I didn't get me problem solved, but all your advice was really good. It turns out my computer has to have its hard drive replaced. "
SOURCE: Blank loading screen
Bad News.. somehow you corrupted the internal software of the GPS. If the unit is in warranty, please return it to Magellan
Mike
Posted on Dec 08, 2010
