Question about Nordic Track Exercise & Fitness
My nordic track 1650 console loops forever. The nordic track reset fix does not work. It has trouble going into the wifi and it recalibrated the incline on its own and wont go back to zero
Posted by Anthony Polito on
5 Related Answers
Anonymous
  • 64 Answers
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Posted on Jun 08, 2009
Anonymous
  • 40 Answers
SOURCE: the incline is frozen in about 6% inclination
Try calibrating the incline. That almost always fixes that problem.
Posted on Nov 01, 2009
Anonymous
  • 12 Answers
SOURCE: I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
Posted on Jan 26, 2010
Anonymous
  • 12 Answers
SOURCE: I have a Nordic Track EXP 1000X treadmill and the
Probably 85% of the time, it's the sensor.
1. remove the screws from the bottom of the enclosure case. 2 or 3 in the front and 1 on each side
lay it back down, and power it up, and actuate your incline. watch the end of the motor, to see if the shaft is moving. It probably IS turning but only a little bit. NOT enough. In this case I'd say it is the sensor.
2. Unplug the unit of course.
3. the incline motor is in the middle of the pack,..you'll see a black tube looking thing sticking up.
4. on the bottom side of this, you will see,..or feel for a black square sensor attached to bottom of the motor casing.
5. follow the wires and unplug this.
6. pry it off with a screw driver. Remove incline assembly, if you cannot reach it.
7. replace sensor and try it again.
if the MOTOR does NOT turn when using the incline buttons, the problem backs up to possibly a bad control board. or a bad motor on your incliner, however, i'd say that's the last thing to go.
Order of failure: 1. sensor 2. control board 3. motor.
good luck
Anonymous
  • 218 Answers
SOURCE: Nordic Track Elite Pro 9500
the motor controller needs replaced
Posted on Aug 11, 2010
Nordic Track commercial 2150 on the i fit screen starts up but then runs in loops, it will not boot up or
Time to replace the Console board CPU, the Clock+power supply inside had been failed.
Treadmill Doctor
Blessing.
[email protected]
cell+whatsAPP:+50588611441
Nov 08, 2017 | Nordic Track Exercise & Fitness
C2250 treadmill incline recalibration - incline goes up, not down
Plug the power out and plug it back in after a count of 50 could be that it needs to be reset .then plug back in the power and see what its doing if no luck go to manual and look for reset
Jan 06, 2014 | Nordic Track Exercise & Fitness
I have the 1750 Commercial Treadmill and the screen is "froze" on the program for the sd card or WiFi. When I push on the stop button or unplug and replug in the power it still is STUCK on that screen. ...
use this steps and fix it. God bless you
Step 1
Plug the power cord into a UL 1449 single-outlet surge suppressor and then plug the surge suppressor into an electrical outlet that is not GFCI-equipped if the power does not turn on. If the treadmill is plugged in and the power still does not work, make sure the key is in the console and that the Reset/Off circuit breaker has not been tripped. Press the switch to "Reset" if it has been tripped.
Sponsored Links
Gym Equipment Choose from 1M+ Verified Suppliers. Contact Directly & Get Live Quotes! www.alibaba.com/Gym-Equipment
Step 2
Check the Reset/Off circuit breaker if the power switches off while in use. Wait five minutes and switch the button to reset. Check that the power cord is still plugged in securely; pull the plug out and plug it back in after five minutes. Pull out the console key and reinsert to see if the machine will turn back on.
Step 3
Place the chest pulse sensor tightly right underneath your pectoral muscles or breasts for it to operate properly. Position it lower or higher on your chest if it does not work properly. Wet the electrodes with a saline solution. Walk near the walking belt's center within an arm's reach of the console.
Step 4
Remove the console key and unplug the treadmill to loosen the walking belt if it slows when in use. Turn the rear roller bolts counterclockwise with the hex key 1/4 of a turn until you can lift the walking belt's edges 3 to 4 inches from the platform.
Step 5
Remove the key and unplug the treadmill to adjust the walking belt if it is off-center or slips when in use. Loosen the rear roller bolts with the hex key and reposition the walking belt. Tighten the roller bolts. Walk on the treadmill to determine if the walking belt is centered. If not, loosen the roller bolts again and make adjustments until the walking belt is centered.
Step 6
Recalibrate the incline system if the treadmill's incline does not adjust correctly. Press the "Incline" button and remove the console key. Wait a few seconds and replace the console key. The incline will automatically recalibrate by moving to the maximum incline level and then the minimum level.
Step 7
Press the "Stop" button for a few seconds to turn off the demo mode if the console display stays lit after you remove the console key.
Read more: http://www.livestrong.com/article/241157-nordic-track-treadmill-troubleshooting/#ixzz2geWlKdPR
Oct 02, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
I have a viewpoint 3500 nordic track and the screen doesnt work. how can i fix it?
Did you get this fixed? I'm having the same trouble now and can't find a solution any where!
Sep 10, 2013 | Nordic Track NordicTrack Viewpoint 3500...
Nordic Track x9i screen stuck in boot
Disconnect wifi and boot machine. This works well for a non-internet workout. I had a similar problem--endless looping of the boot up routine--which ultimately fixed itself when I tried updating. I believe they came out with a new update which must have fixed some bug in the system.
Dec 16, 2012 | Nordic Track Incline Trainer X9i...
Ifit console will not load keeps running in a loop?
try to RUN the software calibration, see your instr. manual how to enter and proceed for easy diagnose, troubleshooting, and fix it.
God bless you
Dec 11, 2012 | Nordic Track Incline Trainer X9i...
Nordic track treadmill console is faulty
Dear Sir:
The problem is a( Faulty batteries b( Tight the flexible cables from keypad vs display board 3( tight the connector from display board vs lower board 4( adjust the Reed switch see the diagram for ilustration 5( Main motor board is faulty.
Try to run the software calibration for diagnose and trouble.
See my personal TIPS for HELP.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 11, 2012 | Nordic Track NordicTrack COMMERCIAL 1750...
Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Apr 05, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track exp 2000I. Consol lights, buttons do not work.
If the console lights up but the buttons don't work, then unfortunately it's probably the console and they're not repairable that I know of. You may want to check the wiring harness and the connections at the console and at the controller under the motor hood. Pull them apart and check for bent pins. If they look good, the console is most likely bad.
Mar 04, 2010 | Nordic Track Nordictrack Apex 4100i...
Exercise & Fitness Logo
171 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
stargajzer
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
