Washer quit with water in bottom of tub
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
SOURCE: Water leak from front load washer - Frigidare GLTF1240A
just remove bolts, open bit enough to fill with silicone, close back wait to dry, ready to go for couple more years.
SOURCE: HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
SOURCE: I have a new electrolux front load washer. When
Mine only smell mildewy if I leave them in more than an hour before drying. My old top load washer did the same thing. I dont wash unless I can immediately switch to the dryer.
Hey friend, thank you for allowing me to assist you!
It is normal to have water in the tub after your Frigidaire washer has completed the final spin cycle. The water that is in the tub is there to help prime the pump. Hope this information is helpful. -Matt
