Question about Razor E100 Electric Scooter
What is the proper wiring sequence for a Tao Tao 501 48v for the batteries
Posted by Vincent Rausch on
2015 Tao Tao 50 no spark
Hi, Clinton and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Faulty run/off switch
11. Tilt sensor needs a reset.
12. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Trouble Shooter Guide for NO SPARK Chinese Engines Only 0 00
My scooter has no spark how to fix gy6 chinese scooter 139qmb qmb139 50cc...
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
https://www.taotaopartsdirect.com/collections/thunder-50
TaoTao ATM50 A1 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 12, 2018 | Motorcycles
Does the tao tao 48volt 500 watt bike have any fuses in the wiring harness 2010 model
if it has they will be inline fuses near the positive terminal of the battery
Nov 10, 2017 | Motorcycles
Ignition switch for a 49cc Tao Tao scooter and an ignition switch wiring diagram
Hi, Michael for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your TaoTao, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Tao Tao 49cc scooter wiring diagram Google Search
My Wiring Diagrams 49ccScoot com Scooter Forums
http://www.49ccscoot.com/manuals/Symply50_Service_manual.pdf
Eagle Atv Parts
Apr 06, 2017 | Tao New Scooter 50cc Street Legal New Look
I have a tao tao 50cc i ordered a performance cdi but it has 6 wire connection and my scooter only has 5 wires what can i do
hi James my guess is its an earth but not 100% sure did unit come with a wiring diagram ?
Feb 05, 2015 | Motorcycles
TaoTao 150 wiring diagram @
Hi, Michael for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
TaoTao 150 wiring diagram Google Search
Tao Tao Evo 150 Wiring Diagram On Tao images Free Download Wiring Diagram...
https://taotaopartsdirect.myshopify.com/
TaoTao 150cc Scooter Owners Manual
Jan 23, 2015 | Motorcycles
How do you purposely short the taillight, brake light, and brake switch on a Tao Tao 110B ATV wiring harness?
You go trying to short a bunch of stuff your going to cause some damage.
Nov 13, 2014 | ATVs
How to remove the from panel cover on a 2008 tao tao 5cc 4strok scooter
Check the alternator output with a multimeter ....great tools worth every penny sounds like you have a bad battery or alternator or sadly both as is usually the case pal
Best regards
Oct 18, 2014 | Motorcycles
Where can i find a wiring diagram for a 2013 tao tao ata 150-D?
google for a gy6 service manual. might find what you need.
Jul 01, 2014 | ATVs
OVO keyring photoviewer software 1.5
this works just fine on Windows Vista, and Vista in XP compatibility mode.
http://taoelectronics.com/downloads/TAO%20Image%20Transfer%204.8.zip
Mar 03, 2009 | Tao Spectare digital picture Remote...
Razor E100 Electric Scooter Logo
98 people viewed this question
Top Razor Toys Experts
ROB
Andrew Taylor
Andrew Taylor
Dennis Key
Dennis Key
Are you a Razor Toy Expert? Answer questions, earn points and help others
