Question about Radio Communications
SOURCE: defect headset
hold the transmitter button for about 50sec until it flashes blue/red quickly and connect the headset afterwards. Hope that helps. God bless.
Posted on Jun 15, 2008
SOURCE: tv wont come on
You may have a Lamp fan that is not turning. You can verify this shining a flashlight in the Fan Exhaust housing and see if it turns when you turn the set on.
Posted on Jul 18, 2009
SOURCE: The headset keeps blinking a red light
I had this very same issue which was remedied when I unplugged the headset recharging dock for approximately 5 seconds then plugged it back in. After about 10 seconds everything re-synced and was fine after that. -No more blinking.
Posted on May 11, 2011
SOURCE: 1. battery light never turns
I opened mine into the on position and the charge light went from blinking to solid red.
Posted on Aug 09, 2011
SOURCE: I can't get the blue
The Plantronics 500A is the base for the 510S system, the headset may
need to be re-paired to the base unit to make sure that it has a strong
link or connection. Here are the links below for the pairing
instructions, and also the user guide.
http://www.headsetsdirect.com/pdf/Voyager%20510S%20Bluetooth%20Headset%20System%20pairing.pdf
http://www.headsetsdirect.com/pdf/510_print_en.pdf
Good luck from Headsets Direct - 800-914-7996.
Posted on Aug 23, 2011
