Question about Furniture
How do I tighten a loose arm Rest on a Brenton Studio(R) Rixie Task Chair, Black/White
Posted by Daren Rogers on
1 Related Answer
Anonymous
  • 97 Answers
SOURCE: Need new arm rest for drivers chair. Where?
i believe you have to get it recovered, or try a salvage yard
Posted on Nov 18, 2009
Instruction manual for Ariel task chair
Do you mean the Brenton Studio Ariel Low Back Task Chair? If so, Office Depot has the assembly instructions on the product page: https://www.officedepot.com/a/products/493642/Brenton-Studio-Ariel-Low-Back-Task/ . The current link to the assembly instructions is https://www.officedepot.com/pdf/assemblyinstructions/493642.pdf .
I hope this helps.
Oct 14, 2018 | Furniture
I am looking for replacement arms for Brenton Studio Black Bellanca Guest chair
Fixya does not sell replacement arms for Brenton Studio Black Bellanca Guest chairs.
Apr 11, 2018 | Furniture
Brenton Studio® Halton Desk, White (761590) installation instructions
Office Depot has the assembly instructions for the Brenton Studio Halton Desk on the product page: https://www.officedepot.com/a/products/761590/Brenton-Studio-Halton-Desk-White/ . Look for the link just below the product images. The direct link to the instructions is currently: https://www.officedepot.com/pdf/assemblyinstructions/761590.pdf .
I hope this helps.
Mar 10, 2018 | Office Equipment & Supplies
Do you sell replacement parts
no
this is an advice page and the advice is to get a new chair or contact the manufacturer and get one from them
Aug 12, 2016 | OfficeMax Finnigan Bonded Leather...
The height-adjustable seat back of my chair tends to fall down, as if it is too loose. Is there an adjustment to tighten this?
The "softness" is similar to shock absorbers in your car. They get tired with time. Most likely you will need to replace those parts. Or a lightly used replacement may be more cost effective.
May 06, 2015 | Tempur-Pedic TP8000 Ergonomic Mesh...
I would like to find out how I can order a replacement arm rest
depending on what chair you have the cheapest option is to try and get a generic replacement, search eBay for "wheelchair arm rest" they start from around 10 UK pounds or you might be able to find one from the same make and model.
if not then you need to search the web for the make and model of chair you have followed by "parts arm rest" so if you have a pride jazzy 1121 you would search google for "pride jazzy 1121 parts arm rest" that should point you to a replacment, if no joy there another option is to contact the makers, again search for maker to find contact info, or look for a dealer that sells the make of chair you have.
if this helps please click "yes" to let others know.
Oct 06, 2014 | Health & Beauty
Slightly wobblyLarge Wheel
Properly inflate tire and make sure wheel retaining nut on shaft has not come loose.
Jun 07, 2013 | Medline Travel Folding Transport Wheel...
The right arm rest on my clients chair goes up and down but it goes the whole way down n lays on the side of the seat. I tried to tighten the bolts n that did not fix the prob. is there something else I...
If you tightened the Arm Angle Adjustment bolt as shown on page 28 of your Owner's Manual (under the arm rest near the pivot point) by using your supplied 1/4" hex wrench, but it does not want to stay in place, the threads on the bolt may have become stripped with age and wear and needs to be replaced. You can also try applying a substance like Lock-Tite to the threads to see if that will keep them in place. If not, the armrest may need to be replaced, approx $118 plus labor to install.
Dec 10, 2010 | NRS Hoveround MPV 5 - Used Power...
Nov 18, 2009 | 2007 GMC Yukon
Furniture Logo
179 people viewed this question
Top Furniture Experts
Tom Chichester
Marvin
Marvin
Are you a Furniture Expert? Answer questions, earn points and help others
