Question about DISH Network Televison & Video
I need the codes for viore tv with a dish network remote
Posted by Stan Jurek on
Will
    Habit-Forming:
  • 91 Answers
Try codes: 738, 915, and 601
Posted on Mar 27, 2020
5 Related Answers
Bob Citizen
  • 520 Answers
SOURCE: Dish Network universal remote
Here are the codes for Orion tv's for Dish Network remotes.
Orion: 694, 720, 729, 220, 221, 623, 695, 227, 754, 721.
Posted on Nov 14, 2008
Jason Morris
  • 362 Answers
SOURCE: remote code for dish network remote to control olevia tvs
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Lone99star. Please rate this solution.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Feb 14, 2009
Jim Franks
  • 374 Answers
SOURCE: Viore tv won't see dish network
I will assume this is a direct connect from the wall plate to the TV. With that said you need to run a scan on the set to lock in the channel the second TV is modulated to either 60 air or 73 cable usually. Go into the menu on the tv and select the auto channel search. Some sets scan both sides at once others require you to choose cable or off air. Once this is done you should find the signal.
Let me know if you need further assistance.
Thanks for using Fix Ya.
Posted on Dec 21, 2009
Anonymous
SOURCE: I need a dish network remote control code for an ESA television.
try some of the akai tv codes in dish network directory, firstone worked for me, hope it works for you
chris
Posted on Feb 13, 2010
Anonymous
SOURCE: need the dish network code to Viore tv
Viore is a generic of Samsung brand TV's. Try using their list of codes, the code for mine was 0085. Hope it helps 8-)
Posted on Mar 15, 2010
Im lloking for a code for a viore tv for dish network remote
Hopefully this has been resolved for you. But if not, here are some simple steps to help you out!
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
738
516
907
Becki Barned
DISH Network Customer Service
Aug 16, 2011 | Samsung Electronics TV Remote
My remote wont let me change the input on my tv i have a viore tv, dish network, and a sont dvd player. Every time i try to change the input my remote only controls the chnnel its on. How do i change the...
Hi there! this is Kimberly Escobar with Dish Network Customer support, I just ran across your post and would like to help you out by providing you the information that can help get this issue resolved. To program the remote to your Viore T.V you can try code 738. What you would need to do is press and hold the clear T.V button located on the upper left hand corner of your remote (you will see all the other top buttons light up) then you will let go of the T.V button and enter the number 738 followed by the pound (#) key, notice you will see the clear T.V button flash 3 times. After this you can try the volume function and turning on and off your T.V. If it works you can try changing inputs on the T.V by pressing the T.V/Video button or Input button on the remote. Unfortunately we can't promise our remote will control all the functions on your T.V we also have this link available that you can as well find very helpful http://www.dishnetwork.com/SupportSection/remote-setup and you are more than welcome to also contact us directly. Thank you hope this helps.
Jan 23, 2011 | DISH Network IR Remote Control
Dish remote code for Viore 32" HD LCD
Hi, my name is Cheri Torres and I am with DISH Network customer service. I came across your post and wanted to see if I could help. DISHNetwork remotes have a few different codes for each of our different models of remotes.You should be able to find your remote model number on the back at the top ofyour remote it's usually a two to three digit number with a decimal point. Iwill list here for you the best codes for the most common DISH remotes and alsothe instructions for addressing your remote to your TV. The only codes that I was able to find for the Viore TV were for the 5.3 IR remote and the codes are 563 and 500. If these codes do not work you can also try running a channel scan to find your particular code. I will also list here for you the instructions for running a power scan. I hope you find these codes and instructions useful and if you have any further questions or concerns feel free to post back here or email me at [email protected] :)
Instructions for addressing remote to TV,
  1. Turn the Television On
  2. Press and Hold the TV mode button down until all the mode buttons (i.e AUX, SAT, TV etc.) light up.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Instructions for running a power scan
  1. With the desired equipment on, press and hold the TV button down until all the mode lights light up.
  2. Press 500 using the number key pad.
  3. Press the pound(#) button once.
  4. The TV button will blink red three times.
  5. Then again press and hold down the TV button down until all the mode lights light up.
  6. Press and release the big red Power button once.
  7. Press the Up button once every second while pointing the remote at the desired equipment. Keep pressing the up button until the TV turns off until.
  8. AS SOON AS THE TV TURNS OFF Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  9. Try the functionality of the TV to see if the power scan worked.
Nov 29, 2010 | DISH Network IR Remote Control
I purchased this funky TV Viore and can't program it to my IR remote control it wont work I have been given several # already and none of the work Model LC26VH56 26" . Can you please help me before I...
sharonc659,
If you have tried the different codes to program the remote to your TV, you can do a power scan to find a code. I have provided a link on how to do the power scan.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
I hope this helps.
Ray Calo
DISH Network
Nov 25, 2010 | DISH Network IR Remote Control
I have a viore tv dvd combo need codes for it
You probably have the same problem that I found after I'd purchased my Viore TV (LC 26VF59), your cable box remote or dish network remote doesn't have the Viore codes built in. Bummer. I looked around and couldn't find codes for my Viore. Doubt you'll find them for yours. Here's a helpful suggestion I read about that works for me:
I bought for $20.00 a Sony RM-VL600 Easy Learn remote control from my electronics store. It's EZ because you only have to place the Sony head to head with the Viore remote, press TV setup and follow Sony's instructions to have its remote catch and learn the codes from your Viore remote. I only programmed my Sony for the Power On/Off, Vol Up/Down from my Viore remote. You back out of Setup and now your Sony will control the TV for those functions. Next you get your cable box or satellite remote put it head to head with the Sony remote, press the CABLE or SATELLITE set-up button on the Sony and then have it learn all the C or S functions you want from that remote. You do program in this mode the Power On/Off button, but you don't program the Vol Up/Down. The volume for the TV will work when you're all finished and operating under the Cable or Satellite button on the Sony remote.
Now, you press the TV button on the Sony and then the Power button. The TV turns on. Now you press the Cable or Sat button and then the Power button and the Cable or Sat box turns on. Like I said, even though now you are operating the Sony remote under the Cable or Sat button the TV volume instructions carry over to this side of the remote so you don't have to switch back to the TV button to raise or lower volume of the TV.
When I'm done watching, I hit the Power off and the cable box turns off. I then hit the TV button and again the Power off button and the TV turns off. So, it's a little inconvenient when starting and stopping, but at least you are using only one remote.
Hope this has helped.
Nov 19, 2010 | One For All URC-3021 Remote Control
I cannot get my dish 20.0IR remote to work with my viore 32 any ideas? codes?
There are two different ways that you are able to addressthe your remote to your television. The first option for addressing the remoteis to use TV specific codes. Listed below are the top codes that work for aViore TV. 738, 516, 322, 907. The first step is to hold down the 'TV' button at the top ofthe remote until all of the buttons light up. Next enter the three digit codethen press the pound (#) button one time. The TV button should then blink 3times indicating that you have used the correct code.The second option is todo a power scan. This can be done by holding down the 'TV' button for 6 secondsand then release. Press and release the big red power button. Press and releasethe channel up button once per second until the TV turns itself off. After theTV turns off, press the pound (#) button once to lock in the code.
Kaia S DISH Network
Jun 04, 2010 | DISH Network IR Remote Control
Dish network code for a viore, volume/power not working
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Apr 05, 2010 | Toymax Viore 42 in. Plasma TV
Dec 13, 2009 | DISH Network IR Remote Control
Need the dish network code to Viore tv
Nov 14, 2009 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Televison & Video Logo
206 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
