Question about Motorola Televison & Video
I have a Motorola RU4160BKN9BA that changes from channel to channel without anyone touching it. It will do so in the middle of a conversation or sitting on the desk by itself. Any ideas?
Posted by John D on
4 Related Answers
Jaime Hernandez
  • 2337 Answers
SOURCE: Display continueuly changes
Unplug your device for about 30 minutes to let the circuitry reset itself.
If it works normally after that, it means a hardware part(s) is overheating inside, more likely a power supply is starting to fail and does not provide the proper voltages for the microprocessor.
Posted on Jul 04, 2008
Anonymous
  • 3 Answers
SOURCE: tv channel will not change and volume keeps increasing without to
Most likely you have a defecvtive volume up switch. Unsolder it from the board, and see if problem goes away. Very common problem. Since only one function can work at a time, none of the others will work until you "release" that switch
Posted on Dec 01, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: I love my RCA...excpect that
Thats the classis sign of a failed small signal board. You can get replacement signal boards from www.tvrepairworld.com
Posted on Sep 29, 2010
SD Tech
SD Tech
  • 14553 Answers
SOURCE: My Hitachi 57F59 was scrolling thru the channels without anyone touching the remote - I unplugged it for two days and now it keeps flashing the
Keyboard issues and answers:A problem that is more common than most people think is an issue with buttons on thecontrol keyboards of modern TV sets.
Recently for whatever reason I have seen more questions about this so I have composed this answer and solution for these kinds of problems.
It can be any button on the set-channel up/down or volume up down-you name it.
The symptoms are the same: channel will scan up or down andwill not stop-remote control has no effect on this---It can be channel, volume,or even input or menu if the set has those up front or on the side of the set.
All these push controls have something in common-beneatheach is a tiny momentary push switch-when pushed with the plastic button itperforms a specific task (vol up or down etc.)
What happens is the afflicted switch beneath the plasticbutton is bad-when released it is supposed to stop its function but does not.
Keyboard or button controlled features have PRIORITYover the remote control, hence the remote will not stop this fromhappening.
Both the remote and thekeyboard go to the microprocessor in the set but keyboard is first in line.
How to resolve this issue?
Someone needs to get at the tiny pc board with the buttonsand locate the one associated with the issue (ie sound or channel etc) andunsolder that switch from the board-usually just two pins (may be more formounting only purposes) and then see if set does not have the issue with switchout of the circuit.
For the TECH minded with the board out test here theswitches with a ohm meter set to high resistance-any reading with button notpressed means a bad switch-seen ones that read 5,000 plus ohms-it may benecessary to unsolder more than one switch to locate the offender here but an open reading with switch not pressed is therule.
I have taken the time to compose this answer as some do notunderstand what is happening in these types of situations---No magic wand orsmoke and mirrors here-have to disable the offending switch to know.
The beauty (in my view) of this kind of problem is if found, you really do not have to replace anypart-just operate the set with the remote with one button that no longerfunctions on the set itself-who could ask for more?
SD TECH
Posted on Jun 01, 2012
2answers
How to remove visual voicemail
Delete: Touch and hold a conversation, then tap at the bottom. Or, open the conversation, touch and hold one message, then tap Delete.
Motorola factory reset
Apps > Settings > Backup & reset . Factory data reset
To Perform a Reset
  1. Open the Applications Tray. (arrow pointing up located in the middle at the bottom of the display screen)
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset
  5. Touch Reset Phone
  6. Touch Erase Everything
For older phones: Master Reset or Master Clear
Mark
Motorola Support
1helpful
How do I change and select channels and frequencies w my motorola axv5100 two-way radio? Can it communicate with a motorola talk about?
This radio comes with programmed channels and tone codes programmed into it. Should it still be stock the the diagram below is what you will use. The tones programed into are there to prevent someone on the same frequency from interfering with your conversation. It's a way of isolating the frequency. These are adjusted by the A,B,C,D You will know what frequency it is by the channel indicated. As for weather or not it will communicate with a Motorola talk about the answer is no. This radio is a VHF frequency and the talk about is MURS.
Regards, Tony
Channel - Pre-Loaded VHF Frequency (MHz) - Code (Hz)
1 151.6250 67.0 2 151.6250 77.0 3 151.6250 88.5 4 151.6250 179.9 5 151.6250 None 6 151.9550 67.0 7 151.9550 82.5 8 151.9550 94.8 9 151.9550 179.9 10 151.9550 None
My Panasonic Model: THL32U20A will not respond. You can turn it on manually (not by remote) and once turned on, nothing works, IE: remote doesnt do anything and you cant even change channels or volume etc...
I too have exactly the same fault. The Tv even turns itself on in the middle of the night, i have to unpug it from the wall. It has been in for repair 3 times now, one guy said there is nothing wrong with it. I am keen to hear if anyone has had this fault resolved.
Thanks
Darren
I got a text with a pic attached to it on my motorola cliq. how do i save the pic?
In the conversation, where you would touch to see the picture, touch and hold. You'll get a screen pop up with some options. touch "Save Slideshow". You can now view the picture in picture gallery.
1helpful
Uniden pc66xl phillipines mosfet conversion erf2030 by ekl
Change the stock final to a 2SC1969,put a jumper across D10 diode that connects from VR5 to the audio transformer,adjust L10,L9,L8.Change C91 to a 33uf 16 volt polarized capacitor.....hope this helps............
Motorola Talkabout Basic
I believe you do not need to hold the monitor button when changing channels
Push the talk button till you have the channel you want then push monitor button to accept
Hope this works
How do I set a channel to scan
Take your radio to your local Motorola dealer for reprogramming. Usually the capacity of a scan zone is 16 channels. I am not certain on this radio without doing some research. Your local dealer will be able to help.
Motorola T6500 does not turn on
most likly where the battery is suppost to touch on the inside of the radio, it is not touching all the point on the radio.
Shutting off
Its defective. While your talking it thinks there is no conversation & enters sleep mode.
Televison & Video Logo
Top Motorola Televison & Video Experts
Joaquim Martins
ray gallant
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
