Question about Furniture
Power lift recliner will not lift,plastic piece broken
Posted by Eleanor Cleland on
4 Related Answers
fusster
  • 65 Answers
SOURCE: power window cable connection point -broken tab on plastic piece
the regulator has broken.you will need a new one.they do repair kits for golfs and beetles but not for passats you have to replace the whole regulator.dont attempt it unless 100% confident they can be tricky.
Posted on Apr 27, 2009
Anonymous
  • 153 Answers
SOURCE: Bowl Lift Mixer does not lift!
well first you shoul read the menual to repair and then call the company and u can replace it.
Posted on Jul 24, 2009
Golden Tech
  • 14 Answers
SOURCE: My Golden Technologies Comforter Series
With Golden Technologies chairs, there is a self diagnostic system. There are LED lights at the transformer and the hand control. If you do have have lights at the transformer, it may be a power issue or a bad transformer. If you have lights at the transformer but not the hand control, it is the hand control. Since you state you ahve lights on the hand control, it is probably a motor issue.
The best thing you can do is call the store which sold you the chair or call Golden directly at 1-800-624-6374. While they do not sell directly to the public, they can point you to a local dealer who can help with the repair.
Posted on Sep 19, 2011
Liz Ritchey
SOURCE: Driver's side front seat will not recline
I have a 2005 Sedona with a passenger seat that quits every few months. The problem I have is in the switch assembly found by removing the collar around the base of the seat. You will see the wire harness that feeds a plastic box. Before opening the box, a warning...Inside there are metal contacts with these little metal balls on top. It would be very easy to loose them and then you have to buy a new switch (I think the dealer said $160!).
Very carefully remove the cover by using a small flat head screwdriver and lifting the edge flaps. (These break easily) The switch contacts that sit under the balls get corroded, so I use an eraser and or the screwdriver to clean everything. Put it back together and we're go to go until the next time my kids have messed around with the seat and got it stuck again :-)
Posted on Jun 30, 2012
Power recliner wont move forward
if you mean forward as in lifting up then it could be the hand control or the motor
Jul 19, 2014 | Electric Mobility Wallaway Electric...
Home Meridian Comfort Lift Chair - lift mechanism is sloppy in partially reclined positions
Bolts commonly loosen up on these. You may be able to tighten them. I had to turn the chair over, pull out some of the staples that hold the material on and find the nut that went on the inside, then I was able to tighten the bolt again and staple the material back in place. I also had to make a new plastic cross bar for the scissor assembly by using a half inch PVC pipe and two flat plugs and two couplings, I then drilled a hole in the center for the screws to go in. Painted the newly made one with black plastic paint from Lowes and it's stronger now then before. If you want parts here is Home Meridian's contact..........
Jan 24, 2014 | Home Meridian Comfort Lift Recliner
My sister manages a funiture salvage store and this power lift recliner came in partly deassembly
When it comes to furniture, there are usually substitute parts you can find online. I would suggest trying to get a discount or partial refund depending on the payment situation. If it didn't come complete, you shouldn't pay the full amount. If worse comes to worse, you can find the same chair but run down and use its parts as substitutes.
Elisa Jed ' http://danielscuderi.com
Jan 18, 2014 | Coaster Furniture Power Lift Recliner...
Drivers seat repair
some have a limiter on them some go to a full recline for sleeping..the best way to know is look at the mechanism for fresh broken steel or plastic..at the worst .. replace the seat..
Dec 15, 2013 | Chevrolet Monte Carlo Cars & Trucks
Beware of Ashley Furniture, we opened up its recliner after its motor stops working, and found that the APEX A-88 motor from Taiwan is using a PLASTIC turbine that has much of the rotor plates damaged....
Ashley customer service has a fix but requires both drives, power unit and switches to be replaced. Before you call you will need your serial number off the bottom of your chair. They do cost money after the short warranty expires.
Aug 17, 2013 | Ashley Furniture Ashley 4240186 Reclining...
Recliner foot rest bolt broke and spring came off
looking for two small springs that go in the foot lift section of a lazy boy recliner. these springs allow you to raise the foot lift to different positions. these are very small springs and attach to each side of two small drum types.
Mar 22, 2013 | Lazy Boy La-Z-Boy Power Lift Recliner...
What will it take to fix the power windows. You can hear the motors running but the windows do not work. What is broken
It sounds like the gear for the window has broke some teeth or come off of the track. Take all of the side screws out even where the door handle is and lift up the door piece after you pop out all of the plastic pieces that hold it in and lift up the door piece and then pull out and you can explore the situation.
Jan 04, 2011 | Cadillac DeVille Cars & Trucks
Furniture Logo
158 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
