Home Logo
Question about Home
I have a LG 55LG6000 TV, the power light is on and I have no picture and no sound. just fuzzy scratching noise. OSI: the TV is only 3 years old. Many thanks Howard
Howard [email protected]
Posted by Howard Wasserman on
  • Anonymous Dec 21, 2022
    no emails alllowed,
    do you want endless spam for 100 years/? or worse do not post emails in public ever, ( <<, learn to be safe)
Roger R
  • 2,005 Answers
Please detach all non-essentially accessories from your tv before turning it off and on from the remote. If the issue persists, please power cycle your tv (ie unplug for 30 seconds and then replug). Please check multiple channels to see if the issue persists. If so, you can then reach out to your tv-channel provider to ask if there's a local service-loss in your area that is being worked on currently.
Thank you.
Posted on Dec 28, 2022
5 Related Answers
Anonymous
  • 149 Answers
SOURCE: Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Posted on Jan 01, 2008
Anonymous
  • 23 Answers
SOURCE: I have a 3 year old Maxent MX-42VM11 plasma tv with no pic/sound
swollen capasitors, replaceing will cost $500, so best to get another one, 42'' samsung will sell for about $800. the pn42a450
once a plasma has a problem, fixing it or not, more problems will occure, trust me, i am the flat pannel guru.
Posted on May 02, 2009
Anonymous
  • 92 Answers
SOURCE: LG 50PX1D Plasma TV with dark and fuzzy picture
Z-Sustain PCB will cure it.
It is inside the TV, on the Right Hand Side.
www.chsinteractive.co.uk or Google for a replacement.
Posted on Sep 08, 2009
Andrew White
  • 41 Answers
SOURCE: LG plasma TV turned off, after the picture very light
I think you have a defective power board. the pop sound in coming from the board and giving you a low output voltage. do it yourself price about two hundred for parts.
Posted on Mar 13, 2010
Anonymous
  • 1961 Answers
SOURCE: Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Posted on Jun 04, 2010
I have a 2-1/2 year old LG 60LB7100 TV. When I turn the TV on I get the Lg logo and sound but then I loose picture.
The back light driver can be incorporated in either the power supply board or the main board (model specific). Contact these guys and they will make sure you get the correct part. TV Parts Universal TV Stands DLP Chips ShopJimmy
My lg tv has sound but no picture
Sounds like power supply is failing
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Tv fault finding
try diffrent sources of signal in put then if not work then service it
Our LG tv has started making a vibrating whistling sound when you first cut it on, you can hear it get faster and faster then slowly goes away.. Also over the past few months I've notices the picture
the picture getting darker means the lamp has aged and u need to replace it another thing u need ti replace the mirrors in the light tunnel of the light engine they have faded secondly the noise means the colour wheel has aged you need to replace it u will have to replace the whole light engine cos the color wheel comes inbuilt the light engine and u will be ok ontact lg dealer in your area
3helpful
2helpful
3answers
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
Open Questions:
Top Home Experts
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
