Question about Rotary Tools & Hardware - Others
Daytek rotary clothsline maintenance (oil). how to...
Posted by Tony Gaal on
What is the application or use of z6000 compressor oils?
The MSDS sheet on it may answer your questions.
Mineral Based
Compressor Oils are mineral based air compressor oil designed for use in many rotary screw, reciprocating and rotary vane compressors needing an ISO 100 oil of this type, providing up to 2000 hour oil drain periods.
Synthetic Based
Are a full synthetic, special, ashless, synthetic based oils, designed to provide extended oil drains in both oil injected and oil flooded rotary screw compressors. They contain a special shear stable synthetic base oil to help reduce deposit formation.
http://www.mitsuiseiki.co.jp/Portals/0/images/catalog/pdf/Z6000%E3%83%BBCOMPRESSOR%E3%83%BBOIL-E.pdf
Jan 13, 2016 | Air Tools & Compressors
Recomendation rotary compressor
1 check oil level
2 clean dirty oil cooler
3 replace thermostatic valve
May 09, 2013 | Ingersoll Rand Stationary Air Cooled...
After running for a few hours it gets hot and shuts down but runs fine every morning
Without more info I will have to give you several things to look at. Typically during the hot months rotary units experience temperature shut downs due to the following. Dirty oil coolers. Blowing them out with air my help some but ideally they need to be washed using a degreaser solution. Location. during the hot months poor air flow/ air removal may let heat from the compressor build up in or under the cover or room. This hot air gets drawn in by the compressor and raises the compressor temperature. The cycle continues until the compressor shuts down on high air temp. Maintenance. Poor maintenance on rotary screw compressors leads to shut downs on high temp, high air temps then play havoc on dryers which causes moisture in the air system. Maintenance items that need replacing regularly ( about 2000 hrs) oil filter, air filter, Depending on type of oil used change 2000 to 8000 hrs, seperator @ 8000 hrs. Also the amont element will cause high temps if bad. It is located where the three oil lines come together. There should be 4 screws that hold the cover on. the cover also has a hose connected to it and located close to the oil cooler. This amont element acts like the thermostat in your car. it lets oil bypass the oil cooler or causes more oil to go thru the cooler. the cooler oil and bypass oil mixes and maintains a certain temp. air end temp should run about 195 F and injected temp about 165 F. hope this helps. if you can give more detailed info I can get you closer to your problem.
Jul 13, 2011 | Air Tools & Compressors
Where do I oil my 7570 - it needs cleaned but I'm in the middle of a quilt and it is sounding "loud"
If this is a computorized machine, you do not oil it.
Check the maintenance section of the manual for this model.
May 07, 2010 | PfaFF Creative 7570
Smoke from engine of lawnmower
usually large clouds of smoke are from having too much oil in the crankcase, or tipping the mower so that oil runs into the cylinder. Check the level of oil, and make sure it's not overfilled.
Mar 26, 2010 | Pool & Spa
Oil leak from a Mazda Bongo
Are you sure you are leaking oil? Rotary's are designed to consume oil. How much oil depends on how you drive. Oil is injected into the engine to lubricate the seals. It is normal for a rotary to consume oil. Make sure it stays full, I usually check every 1200-1500 miles or so. The Renesis engine in the RX-8 uses less oil than the previous Atkins 13b's found in RX7's. I believe I have used about a quart of oil in 8000 miles or so and that is with aggressive driving habits. The best way to maintain a rotary's oil consumption is to check in between oil changes and fill as needed. Get yourself a factory service manual for detailed info on your RX-8. I got mine from www.promanuals.net for about $20. The best tool I've bought so far my Rotary.
May 11, 2009 | 2004 Mazda RX-8
I can not find remote codes for the Daytek DVK-5601 DVD player
Well I finally got an answer from Daytek. It's not what I wanted to hear, but thought I'd share it in case someone else runs into the same issue.
"I am sorry to inform you that theres no dedicated universal remote code for Daytek models. However, you can try the code for MTC on our unit and see if it works."
Apr 08, 2009 | Televison & Video
I NEED CODES FOR TV DAYTEK AND HOW TO PROGRAM THIS
we have a 21" daytek hi def tv with no book or control. help?
Oct 31, 2008 | One For All URC-3021 Remote Control
Tools & Hardware - Others Logo
179 people viewed this question
Top Rotary Tools & Hardware - Others Experts
Marvin
Marvin
rwkemper
Level 1 Expert
john h
Are you a Rotary Tool and Hardware - Other Expert? Answer questions, earn points and help others
