Possibly but it indicates a bag ground connection or connection for that unit
SOURCE: Dead battery or starter?
Take the battery out and have it charged up. reinstall it and you should be allright. Your car has discharged it completely, and it will need a recharge to start. The gauge is only measuring voltage, and not the status of charge.
SOURCE: 1996 tahoe won't start
double check battery under load and verify it will hold for 10 seconds without dropping out under 10.5 volts , very possible there is a draw somewhere , check this by pulling fuses one by one with amp meter connected until you see maybe .3 volts .1 volt is normal
SOURCE: 2001 Chevy Impala won't start
If the battery has gone dead, it could cause the security system to go into full lock-up mode. If it has locked up the accessories will work after the battery is charged back up , but the power to the starter will be cut off and it wont turn over. You need to do the 30 minute learn procedure. A GM dealer will print it out for you and you can do it yourself. It's very simple if you follow the procedure exact. hope this helps and good luck.
SOURCE: cadillac 2004 cts, wont start
i had a 2003 ctc that did the same thing, it wouldn't start or would make a clicking sound and about 1 mth after the problem started aND mechanics could not find a problem my car caught on fire and burned completely from something under the right side of the hood. i had just parked the car and got out, it happened really fast. the fire chief said the cause was unknown????
now i have a 2004 cts and i'm having the same problem!!!!!!!!!!!!!!! has anyone else had this happen???? please be cautious if your cts is doing this, during the fire my doors locked and had to be pried into by fire chief.
SOURCE: Replaced stock bcm with used.
A used body control can be used in a vehicle other than the vehicle it was installed in. the body control module when first installed is programmed with the vehicle vin number. the vin number can not be changed was it was written to the BCM. the oprions can be always change in the BCM but not the VIN number. basically the used bcm you have installed has the vin number from the vehicle was installed in, now the vin number in the used BCM doesnt match all the other control modules
Cluster
warning lights
Whenever this warning light or any
other stays on in the dash it is indicating that the systems control
module (or the system sensor in the case of lights like low oil
pressure, door open indicators etc.) has detected a fault, it then
disables the system (this applies to ABS,TCS, TCM, SRS, TPMS, MIL,
CEL and BCM faults and others) as long as the light is on. You must
now have the dealer hook up a special electronic diagnostic tool and
"scan" the system for the fault code that is stored for the
problem(s)
Legend of Abbreviations. ABS Anti-lock brake system. TCS Traction control system, TCM Transmission control module, SRS Supplemental restraint system, BCM Body control module. TPMS Tire Pressure Monitor System, MIL Malfunction Indicator Lamp, CEL Check Engine Light.
problem(s)
problem(s)
