Question about GE Washing Machines
I have a gfws3500loww ge appliance and the front load door wont latch. Its not the switch because it locks fine and i even replaced it already.Male piece on the door is not broke.
Posted by larry beining on
5 Related Answers
Anonymous
SOURCE: REPLACMENT CD LID LATCH FOR DURABRAND MOD. CD-1493
http://cgi.ebay.com/CD-DOOR-LID-LATCH-LOCKING-DEVICE-STEREO-BOOMBOX-PART_W0QQitemZ220225587206QQihZ012QQcategoryZ48626QQtcZphotoQQcmdZViewItem
Posted on Feb 10, 2009
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: GE front load washer WSXH208v1ww door latch
Unfortunately, the "door latch assembly" is what you would need. It comes with a new concrete front tub counter weight which is redesigned to not be able to contact the door latch switch on out of balance spins. It is also a lot of work to replace. (you can not get just the little plastic part) Please don't rate this solution, as anything but a Fix-Ya lowers my score, and I know you don't want to shoot the messenger.
Posted on Mar 08, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Door latch broken
Look in yellow pages if you are in the U/K, and ring Hotpoint service, who are the service agents for Ariston.
Please rate my solution.
Thanks.
Posted on Jul 19, 2009
VtToolMan
Mark
  • 704 Answers
SOURCE: Broken door gasket how to replace on GE front
You'll need to determine which bellows gasket your washer needs before you undertake the repair. Go to the following link and enter in your washer model number to get the line drawing and parts breakdown.
http://www.searspartsdirect.com/partsdirect/index.action?pop=flush
Click on the "find a part" and enter in your model number
Typically, the tub gasket (door seal) is part number #WH08X10022 with a new substitution part #WH08X10036. However, since each model can be slightly different, depending on the serial number which denotes when it was manufactured, you might want to confirm that the above gasket is the correct one for your particular washer.
You can also call the folks at Sears Parts Direct at 1-800-252-1698 and give them your complete model number AND serial number before you start in on the repair, so you can be sure you have the correct substitution bellows gasket.
It's a relatively easy repair, all you need to do is remove the spring retaining wire around the outer edge of the bellows gasket, just peel it back at the edge to see it. Now locate the locking loop by going around the rim. Once you find the locking loop, you can remove it using a couple pairs of small needle nose pliers as they make it easier to get off.
Once you've done that, you'll see the locking plate that holds the back side of the bellows gasket onto the outer washer tub. Remove those fasteners and you can get the bellows off and start in on putting the new bellows onto the washer, just reversing the order you used in the removal process.
Just take your time removing the old gasket so you remember what you're doing and when installing the new gasket so as not to rip or tear it in the process. I'd also suggest you let the gasket relax for a good 4-5 hours (to get the kinks and folds out of it from the packing box) before you do the installation.
Here's another link to one of my other solutions for installing a bellows gasket on a GE front loading washer that you can also review for more installation tips, etc.
http://www.fixya.com/support/t2730376-need_help_in_installing_door_bellow_ge
Hope you find this Very Helpful and best regards!
Posted on Sep 17, 2009
Anonymous
SOURCE: door won't close/lock
Just had the same issue. The latch, which rotates up and forward, is spring-loaded towards the rear. If 'tripped' to closed position, it cannot rotate back down until it's carrier/hinge slides slightly forward. I bent a sturdy wire into a long 'U', then bent both ends down (~3/8in) and slightly outward to hook over the latch-hinges and pull both sides gently (its plastic) forward, while rotating the latch downward with a small screwdriver. be careful to keep what appears to be a brown plastic button raised, if it pops down from above the latch. Yes, having 4 hands would help, but the 'U' wire can pull from behind the two outer edges with one finger. Once the latch rotates down, release tension on the 'U' wire and extricate it - problem solved.
Jon (We don need no steenkin manuals)
'Build a more idiot-proof machine, and the universe will build a better idiot.'
"We don't take no s*** from no machines."
Colonel Jason Grant (Walter Koenig), Moontrap 1989
Posted on Dec 19, 2010
GE front load washer model WCVH6260HWW unlock light stays on, machine won't run
Possibly need a new latch assembly per the suggestions at the link below:
https://www.repairclinic.com/PartDetail/Door-Lock/WH10X10006/1168668
https://www.justanswer.com/appliance/38tio-front-load-washer-reads-door-locked-model-xxxxx-when.html
Question asked many years ago:
3/11/2010
Appliance Technician: Tyler Z.
You will need to remove the lower front panel. There are 3 screws along the bottom. Remove these screws and remove the panel. Next, pull the plastic pull tab on the bottom of the latch assembly to manually unlock the door latch and then shut the door. Then start a cycle and cycle it to see if it will unlock on it's own. If not then you need to replace yoru door latch assembly. Here is a link to the part.
CLICK HERE
Tyler Z., Appliance Doc
Category: Appliance
Satisfied Customers: 87,538
Experience: 9+ years being an appliance technician with factory training.
We tried this and it did not release...is there anything else we can do?
not really unfortunately, you can try holding the door switch button in and try to start and cycle a cycle but I'm not sure that will work either, it sounds like you might just need a new latch assembly.
Does the latch have an actuater that would buzz or make a weird noise during a cycle?
not really no.
Front Load washer reads door locked model wcvh6260hww when
Jun 09, 2018 | GE Washing Machines
I have a FE WCVH6260. Multiple times every cycle the machine door will unlock, and the cycle will stop. It will only restart when the "start/stop" button is pushed again.
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
Aug 11, 2008 | GE Washing Machines
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
Dec 13, 2015 | Washing Machines
My washer wont lock and now it does not spin why
The door has to lock as a safety to allow the machine to run. There is a switch on most locks to tell the machine to power the motor.
I would guess the lock solenoid has failed, or something has happened to the latch for the door.
Sep 16, 2012 | GE WBVH6240F Front Load Washer
Affinity model # LAFW7000LWO front load washer wont start says" door is opened"..which it is not..have checked for blockage and vent latch
Hi.
When that happens you usually need to replace the door lock. The door switch can be tested reading impedance. To test the door switch disconnect its contacts. Disconnect power first. Set multimeter on impedance (Ohms) Touch the switch contacts with the multimeter probes. The multimeter must read zero or low impedance (a couple of Ohms) when door is closed, infinity (circuit open) when door is open.
Here diagrams for your appliance: LAA7000W0
Parts in Au and NZ are available here: APWagner Appliance Parts..
Call vendor to obtain parts in other locations.
Regards.
Ginko
Aug 31, 2011 | Washing Machines
The door on my washer won't lock!
the door lock has internal relays, if they go bad, the motor control board will not function. Even if you cant physically see anything, and even if the door still locks, the door lock assembly is still the most likely problem and needs replaced. The only way to test it is with a multimeter to know for sure before you buy a new one
Oct 19, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Washer front loader
Does your model have a Male Female latch, where the femal receptor of the male plug is plastic?
Regards,
Worldvet
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ge front load wcvh6600.
our door kept sayin "door locked". a technician came out to see it and said it was the door lock but that he had temporarily fixed the problem. he said to call if it happened again and would have to order new door lock which runs about $160. after six washes it said door locked again. he came out agian and within 5 minutes of diagnosis said it need a new door lock. i was furious bc i had already payed him and found an new door lock on Ebay for about $70. Got the manual off the internet and had my hubby replace door lock. not very hard except when he replaced it it still said dook locked. after several hours i told him to unscrew the bottom panel because i had seen tec do the same. to our amazement, one of the wires had come loose and needed to be plugged back in. amazingly it started working perfectly. then , i put a big load of towels in and it started shaking badly again and the same problem reoccured. DOOR LOCKED. so we took the bottom panel off and the wire had com loose again. we stuck it back in and wah-la... it worked again. this has happened about 4 times now and everytime we just open them bottome panel and replace wire. i believe we never even needed the new door lock to begin with? we havent checked putting the old door lock back in but i bet it would work because it looked like nothing was wrong with it when we took it out. I hope this helps before you spend an extra $200 or so like we did for a loose wire. we have now just left the front bottom panel off and when it happens, i just bend down and tighten. Hope this helps.
Apr 26, 2008 | GE WCVH6260F Front Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
