Question about Furniture
I have a Kenmore model 1********** wine cooler that doesn't run. Getting power to unit but no clicking or other noises. This unit is about 12 years old. Don't know if it's worth fixing.
Posted by raymond dinoi on
5 Related Answers
Anonymous
  • 33 Answers
SOURCE: Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
Posted on Jan 01, 2008
Anonymous
SOURCE: U-Line 15WC Wine Cooler Problem
I just had the same problem. Also, I was getting a burning smell. The coil on the unit was blanketed with dust and dog hair. First, I cleaned it all out and tried it. It really didn't do much and I still had the burning smell. I then opened the back and recognized that the fan was not working. Turned out to be really dirty. Cleaned it and no it is working fine.
Posted on Oct 18, 2008
Joe Hogan
  • 10865 Answers
SOURCE: my water cooler runs but it doesnt cool anymore,
Hello. The sad reality these days is that a service call is generally going to cost you about $100. or more. You can purchase a new and much more efficient cooler at a box store for a very low price. AND, many bottled water companies give you a loaner cooler if you have them deliver the water to you.
Posted on Nov 11, 2009
Anonymous
  • 27 Answers
SOURCE: my ewave made by magic chef model mcwc 30 mcg wine
it could be the ptc relay.to the left of the compressor.if its clicking its the problem.around $27.00 fix at repairclinic.com..part #1206838 the part is behind the plastic cover with 1 screw left of comp.the top part with 1 wire will wiggle off to the left.
Posted on Aug 07, 2010
ROBERT WILKINSON
  • 16 Answers
SOURCE: Danby wine cooler DWC440 stopped cooling - makes clicking noise
sounds like you need a new start kit or your compressor is lockedup. get a supco 3in1 for fractional hp compressors.wire it in correctly! you only get one chance at the last step.
Posted on Nov 28, 2012
Just plugged in my new 12 bottle Danby wine cooler and it hums, LOUDLY. Any idea why?
it might , it has a compressor and that would make more noise under a strain . refrigeration units strain when the box is warm. let it run and bring down the temp of the box and then see how much noise it is making . 12 hours should do it.
Jan 30, 2016 | Danby DWC1233BL-SC 12 Bottle Wine Cooler
Plugs in but wont turn on
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric ...
www.amazon.com/Koldfront-Bottle-Stainless-Slim-Fit...
Amazon.com, Inc.
Rating: 3.7 - ‎42 reviews
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric Wine Cooler - Black/Stainless Steel ... Item model number, TWR121SS .... the fridge. so you hvae to take out a wine bottle to reach it an usually I would like the controls on the door and only turn in .... The door can be reversed which the description did not mention.
www.edgestar.com/Koldfront-12-Bottle-Stainless-Steel-Slim-Fit-Thermo...
Koldfront 12 Bottle Stainless Steel Slim-Fit Wine Cooler Primary Image ... steel, the Koldfront 12 Bottle Slim-Fit Thermoelectric Wine Cooler (TWR121SS) is ... cabinet and stainless steel accents ensure that this freestanding unit will look ... Power: 70 W/0.95 A .... Unfortunately, your browser does not support video elements.
www.walmart.com/.../Koldfront-12-Bottle-Stainless-Steel-Slim-F...
Walmart
$109.99 - ‎In stock
Jan 20, 2016 | Koldfront 12 Bottle Stainless Steel...
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Jul 09, 2012 | Haier HVFM20ABB Wine Cooler
Wine cooler displays temperature setting but does not run or cool wine.
It's 1 of 3 things...
A. The fans are not turning. Remove the back, and see if the fans are getting 12 volts, and spinning freely. Remove them and clean off the dust from the heat sink.
B. The Peltier Chip is shot. If the fans run, check for 12 volts on the power connector that's on thelower left of the curcuit board. If there's power, but no cooling, the Peltier is shot. These are available from E-bay for ~$13, but it's a major dissassembly to get it out.
C. If you don't get 12 volts to the fans or the Peltier chip, replace the circuit board.
Dec 15, 2010 | Cuisinart Private Reserve CWC-600 Wine...
Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
May 04, 2010 | Haier BC112G Wine Cooler
Does not cool the wine,back panel is warm and unit is making a no
If your condensor fan is running and the compressor is running then you will need a tech to look at the sealed system for you.
May 26, 2009 | U-Line 15WC Wine Cooler
Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
May 03, 2009 | Haier HVFM20ABB Wine Cooler
Power Consumption - Magic Chef Wine Cooler
The unit will draw between 6 and 12 amps on start up and running it should use less than 1.6 amps. The start up amps will increase with age. Funny how that works the same for people as it does for machines. I hope this will FixYa. Please dont forget to rate. Mike
Sep 23, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Cheak The Compressor relay is fault
May 20, 2008 | U-Line 75WC Wine Cooler
Furniture Logo
151 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
