Question about Vacuums
Where can i buy a brush bar motor Everywhere i look they say it is no longer available
Posted by Ed Hirt on
Thatvacguy.com
  • Vacuums Master
  • 1,604 Answers
What is the make and model number of your vacuum?
Posted on Oct 23, 2018
1 Related Answer
pyralid12
pyralid12
SOURCE: Bottom agitator brush bar doesn't rotate.
First, check to make sure the brush bar is on. The switch is right next to the machine's on-off button, and it is easy to accidentally turn it off when you turn the DC 25 on or off.
Next, check for and clear any obstructions in the brush bar housing.
Finally, check for belt wear and replace if necessary. There is a very video online showing the procedure.
Posted on Aug 08, 2012
Beater bar isnt working I have replaced motor on dyson dc18
Be sure you are getting power to the brush bar motor. Power comes from the main switch to the brush bar switch, then to the micro switch that activates when the handle is reclined, then to the brush bar motor. Any openings in the circuit will cause the brush bar motor to not work.
Jan 23, 2017 | Dyson Vacuums
Tip
Common generic problem with Dyson upright vacuum brush bar
I see lots of problems with Dyson vacuum cleaner brush bars not revolving, this is normally because the belt has broken, this is an easy and relatively cheap fix. Remove the sole plate normally held by a couple of quarter turn plastic connectors, once the sole plate has been removed the brush bar can be lifted out of it's slotted position, remove the remnants of the old belt. With the new belt manouvre it over the motor spindle first then position brush bar through belt and slot the brush back into its slots and reattach sole plate. This procedure should take no longer than ten minutes even for a total novice.
on Apr 16, 2010 | Vacuums
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Why is my hoover spin brush making a loud noise when i turn it on
    Check for clogs starting with the air passageway at the bottom.
    A piece of TV cable or similar works well as you have to snake
    it in. Check all hoses, Are the filters clean? If you can, remove
    the brush bar and belt then turn vacuum on. If the vacuum is
    no longer making a loud noise the side bearings on the brush
    bar are the problem...replace the bar or spray a bit of WD40-
    if you do that wipe well before you vacuum. Finally....if the
    vacuum was still loud with the brush bar off...you have a motor
    problem and that could be expensive.
    Regards.
    Dennis
    Aug 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
    Why want the beater bar turn?
    There are a few things it could be. Pull the handle back into the vacuuming position and turn the brush bar switch on and off while listening to see if you can hear the brush bar motor turn off and on. If you can hear the brush bar motor running it may need a new belt and/or the brush bar may be seized up.
    There is a switch by the main power switch that provides power to run the brush bar motor. There is a micro switch down in the motor area that closes the circuit to the brush bar motor when you pull the handle back. Check electrical connections and all of the above parts to determine which one or one's may be defective.
    Jul 09, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Beater bar
    It could be your brush bar is not working properly if there is debris restricting the endcaps, the brush bar motor could be defective, it could be a switch or wiring problem.
    Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Dyson dc24 roller brush stopped spinning
    There are two switches to check. The push button switch on the handle and the other one that turns brush roll on when you recline the handle back.
    Feb 02, 2018 | Dyson Ball DC24 Bagless Upright Vacuum
    My roller brush no longer rotates?
    DC07s have two drive belts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
    You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
    If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
    Have a look at www.dysonmedic.com which has some excellent info on dismantling and repairing a DC 07, but unless you have access to such tools, and feel confident to tackle it, it's probably time to call Dyson or a Vacuum repairer.
    Sep 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    The brush no longer spins when in the carpet position.
    DC7s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
    Aug 17, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
    take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
    if it sucks your hand onto the tube , the machine is working as a vacuum machine
    then check fro a blockage in the elbow section near the head
    if there is no vacuum , junk it and get a new one
    Jun 30, 2017 | Hoover Vacuums
    Vacuums Logo
    61 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
