Question about Dewalt Tools & Hardware - Others
I have a dewalt 18g DC608 finishing nailer I bought, and I’m using it with a 18v adaptor with 20v batteries. It lights up and fires maybe three nails but when the motor gets going it always cuts power and I have to remove the battery and put it back. Anybody else had this problem?
Posted by Matthew on
Parson's Repair Shop
    Sergeant:
  • 234 Answers
That symptom usually indicates a low voltage issue - not sure how the adapter may affect this, I've never run them with a 20v battery.
Try it with a standard 18v and see if you have the same issue - please comment back with the results, I'm curious.
Posted on Feb 02, 2019
5 Related Answers
John Trevino
  • 1420 Answers
SOURCE: D51844 Won't Fire Nails
The Dewalt D51844 uses a full round head 20 degree nail. Sometimes the generic brand nails are not made exactly to the stated degree. They do this so their nails will work on a variety of nailers. Best to check the nails angle in relation to the angle of your nailer. Place a strip of nails on the outside of the rail. Align the heads of the nails to a convenient straight edge on the rail then check that the head and shaft of the first nail is aligned with the barrel. If the lower part of the nail projects out further than the head, then the driver will miss the head. If the head of the first nail appears close enough to barrell for the driver to hit it then place a new strip of nails into the mag and slide the pusher foward. Fire one nail, if success, remove the nails from the mag and check if the plastic holding the nails together is projecting in front of the first nail. Sometimes the plastic is not right, too stiff, and will not let the next nail align with the barrell. If the next nail appears ready and slides forward then the driver may not be going all the way up after shot. Check by inserting a metal rod into barrell and push driver up till it stops. If the driver is in the uppermost position, then most likely brand of nails. Use Dewalt nail. Good Luck
Posted on Feb 25, 2009
comax
Corey McConnell
  • 154 Answers
SOURCE: Mastercraft Brad nailer piston always fires
The dial on the top of the gun is most likely the depth adjustment for the nails, this should solve the driver damaging the work piece. Make sure the nails are the correct guage for the nailer you have.
Posted on Apr 14, 2009
Anonymous
  • 583 Answers
SOURCE: dewalt dc608 motor wont run or shoot light stays
seek advice at TOOLKING
Posted on Jul 26, 2009
rcalorisian
Randy Trent
  • 313 Answers
SOURCE: carraige in dewalt nailer
just goto:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
download the support manual. You should be on your way
Posted on Sep 08, 2009
Anonymous
  • 8 Answers
SOURCE: nail gun wont fire
First - the air pressure has to be high enough - check the regulator on the tank to make sure it is delivering in excess of 60-70 psi (which I am sure you have already done).
If you have dry fired these guns (i.e. shot them off with no nails in them while you were lubricating them maybe) the mechanism inside could be damaged. I had that happen to one of my nailers (same brand). That was when I learned not to dry fire them...
Since both of them are not working though I would be more inclined to look at the air supply first.
Posted on Sep 10, 2009
My dc616 dewalt nailer is not firing and constant flash not battery no jambed nails what else could it be
look at the end where the nail comes out . it should be flush across , if the plunger is sticking out then push it back in with a flat screw driver and try again.soft wood quite often lets the nail shoot to far
Aug 13, 2015 | Dewalt DC616 16g Cordless 18v Straight...
My brand new DC608 18 gauge nailer jams every time on the 2nd nail.
Per your addendum I would have first told you to check that you are using the proper guage nails. Second you should make sure you are loading the nails in the lowest channel in the magazine so they are at the bottom of the magazine. If you load them into the top of the magazine they have more time to go off course before they get into the wood.
May 29, 2012 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
I have a DC608 cordless nailer that will not fire the driver the driver does not move at all but everything else seems to be functioning properly Thanks Tim
You can go to this webpage and download the owner's manual which gives instructions: http://servicenet.dewalt.com/Products/Detail?productNumber=DC608K
You can also download a parts diagram and order parts here.
I looked through the manual and found that DeWalt's Brad Nailer does not require tools to remove jammed nails from the nose piece. I believe this is the problem with your nailer, unless it's empty. Some of these nailers will not fire if there's less than 6 nails in them.
Another feature on this nailer is the trip lock. It is a safety feature that prevents accidental firing. Any time you adjustments made to the nailer will automatically turn the trip lock to lock position. You'll find this lock on the right side, under the Dewalt label.
The instruction manual will explain all this.
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | Dewalt DC608K 18 Gauge 2-inch Cordless...
The pin on my Dewalt dc616 cordless finish nail gun is ceasing up. How can i lubricate it? can i spray silicon into the nose of the gun?
Hello, W/D here.
The better way is to disconnect the air line from the gun, and place several drops of light oil in the gun while holding the trigger down. Oil daily. Then, re-connect the hose, and fire a few nails into scrap wood.
Another trick is to spray your nails with WD-40 before you load them into the gun.
Best regards, --W/D--
Feb 09, 2011 | Dewalt DC616 16g Cordless 18v Straight...
My DC616 a straight 16 gauge DeWalt finish nailer tries to drive 2 nails when it fires 1 out of about every 5 to 10 shots. I am a finish contractor and have used this nailer for about 6 years. I was...
Argh...
Had the same problem, but only after about 4-5 nails. Once it jammed 4 times in a row - very frustrating.
I read the manual, took the unit apart, checked the driver - it was straight. I took a file and filed the back end of the driver down a bit so it would miss the second nail and so far it seems to be working famously.
Great unit...
Sep 07, 2010 | Dewalt DC616 16g Cordless 18v Straight...
My dc 616 wont fire. the lights are on solid when first put battery in then when you depress nose to fire, it clicks and the lights flash constantly thereafter
The driver is probably stuck. The manual tells you how to access the front of the device. Check there (I have also had several hard to find jams) - be sure to remove all nails first.
The driver is silver in color, so it's easy to see if it's jammed. Use a slotted screwdriver to push it back up. I have had this happen more than a few times.
Aug 13, 2010 | Dewalt DC616 16g Cordless 18v Straight...
Dewalt cordless nail gun fires but doesn't seem to feed the nails very well, alot of misfires.
Try another brand of nails -- maybe your gun doesn't like those. Also, blow any dirt out of the nail magazine.
Sep 25, 2009 | Dewalt DC616kn 18 - volt 16 - gauge...
Tools & Hardware - Others Logo
345 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
efs_perpends
efs_perpends
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
