Question about Buffalo Tools Electrical Supplies
Buffalo tools sportsman gen154 wiring schematic
Posted by Ray Johnson on
1 Related Answer
Tom Chichester
  • 55962 Answers
SOURCE: wire schematics manual for sportsman generator 7500df
Request this information from Sportsman.
Posted on Jan 06, 2017
I need a wiring diagram as my son connected the battery wrong negitive to positive need to see what all is wrong
There is a fuse link at the Positive battery terminal wire. It will blow to protect the circuits if the battery is hooked up backwards.
It is a smaller gauge section in the wire that melts to save systems. any auto parts store has one
MDS
Mar 26, 2016 | Polaris 2004 Sportsman 500 H.O
How come no spark?
ignition not switched on -faulty switch
problem in oil level unit not completing the circuit for the coil
they are know to be a source of faults
Oct 20, 2015 | Sportsman GEN154 2000 Watt Portable...
How do i stop this unit from cutting off
Give us a call when you are with the Generator and we will run through it with you. Call your local office and speak to an engineer: http://www.generatorguru.com/ask-the-guru/
Generator Guru
Aug 31, 2015 | Buffalo Tools GEN154 Sportsman Series...
How do you remove the rotor on a sportsman gen154 generator?
The bolt in the end where the exposed bearing is a very long bolt.It goes thru the entire length of the generator and threads into the crankshaft of the engine. Loosen this bolt slowly but firmly since it will twist a lot before it breaks the threads loose. Once the bolt is out if the rotor doesn't come off easily, then give it a nudge with a rubber mallet.
Jun 18, 2015 | Electrical Supplies
Have a 4000 watt sportsman generator that will not produce electric i have replaced the avr what next
Could be lost exciter current. This is how to restore it - Connect 16 or 18 gauge wires to a 12 volt battery. With generator running, insert bare ends of wires into AC outlet - one to Hot, the other to Neutral. Insert and remove quickly. There should be a flash and power will be restored. If not, repeat until you get that flash and output current restored. Using light gauge wires is so that if you are too slow to remove them once AC is restored. they will burn out before the battery suffers from the AC incoming. Be quick and be careful.
Mar 31, 2014 | Buffalo Tools Sportsman Series 4000 Watt...
Recoil broken
find out who manufactured the engine... if it's a honda knock off a honda recoil might work and you can get an after market one for cheap... like $30 USD or something close
Dec 26, 2013 | Buffalo Tools Sportsman 4000 Watt...
My portable generator runs great but only produces 7 volts and 20 volts on each 110 volt receptacle and 20 volts on the 220 volt receptacle. any ideas on troubleshooting steps to find the problem part?
Assuming the speed is correct check the voltage on the rotor brushes during running (Caution) It should be DC. If you have low or no DC voltage then the capacitor in the end of the generator housing is bad, or the AVR. If you do have voltage then make sure the slip rings are clean and shiny, from there you may have a rotor or stator issue that needs carefull resisitance check
Oct 13, 2013 | Buffalo Tools Sportsman GEN7000LP Portable...
Sportsman generator wiring
I know this is an old post, but did you ever find out? Im in the same boat ...i just need the 3 or 4 wire locations behind the switch on the left side, not the harness on the right side ..any help?
Mike
Jan 27, 2013 | Sportsman GEN154 2000 Watt Portable...
Electrical Supplies Logo
106 people viewed this question
Top Buffalo Tools Electrical Supplies Experts
Lawrence Oravetz
Bill Boyd
Generator Guru
Generator Guru
Level 1 Expert
Are you a Buffalo Tools Electrical Supply Expert? Answer questions, earn points and help others
