Question about Golf
I have a caddytek 4 wheels golf cart one push. The left brace has stated to pop out, and now the right brace is poping out. Any solution?
Posted by Linda Girard on
5 Related Answers
csmock132
Clint Smock
  • 4669 Answers
SOURCE: 2004 silverado front right wheel grinding.
Is the Cv boot torn?
Posted on May 11, 2009
super_guy
  • 1986 Answers
SOURCE: replacing right side mirror
I can't say for sure with your car. On some cars, this cap just pops off with some pressure. On a lot of cars though, this cap is hooked (held back) by the door panel so that even if you got the cap off, you can't get it back in with the door panel in place.
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door.
Posted on Sep 29, 2009
Anonymous
SOURCE: Poping sound when turning all the way right or
cv joints
Posted on Oct 14, 2009
golfcartman
  • 34 Answers
SOURCE: Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
Posted on Apr 22, 2010
daltonp
Paul Dalton
  • 361 Answers
SOURCE: when going down the
I am assuming it is a front wheel drive vehicle? If it is the problem is probably the CV joint on one side or both, is it a clicking or popping noise?
Posted on Nov 30, 2010
What is the right air pressure for sun mountain golf cart
8.What is the recommended tire pressure for the Speed Cart pneumatic tires?
The recommended tire pressure is 30 psi.
FAQ ' Customer Care - Sun Mountain
https://shop.sunmountain.com/faq.html
You may also purchase products directly from any of the preferred internet retailers or shop.sunmountain.com. ... If the tire pressure checks out and you have a cart outfitted with bungee cords or strapless bag bag bracket you can adjust the alignment by following the instructions in your user's guide. If you have an older cart ...
[PDF]Speed Cart® SVl User's Guide - Sun Mountain
https://www.sunmountain.com/images/userguides/SV1_UserGuide.pdf are perfect for balls, tees, snacks and keys. • Mesh headcover tray. accessories include the. Speed Paq and. Umbrella. • Ergonomically designed to push without straining your shoulders or back. • Large diameter f tires are maintenance free. I. • The E-Z Latch System / makes folding and unfolding the cart simple.
[PDF]Speed Cart® V2 User's Guide - Sun Mountain
https://www.sunmountain.com/images/userguides/V2SpeedCartUserGuide.pdf Speed Cart® V2. User's Guide. To take full advantage of the ergonomic features of your new Sun Mountain. Speed Cart, please read the following information. ... on the side of the brackets, place your golf bag on the cart and retighten the thumb ... your manual brake is not holding, first check the tire pressure on the front.
[PDF]Speed Cart Vl User's Guide - Sun Mountain
https://www.sunmountain.com/images/userguides/V1SpeedCartUserGuide.pdf *Reverse these steps to fold and store your Speed Cart. STEP FOUR: STEERING. To steer your Speed Cart push down on the handle so the front wheel lifts slightly off the ground. Then pivot tight or left to change direction, lower the front wheel and go. When adjusting the handle or folding the cart, please note that the tires.
sun mountain golf cart tire pressure Google Search
Mar 12, 2018 | Golf
1986 ez electric 4 seater golf cart serial # 438359
re wire the golf cart. poor ground and possible battery replacement needed
Sep 15, 2016 | Golf
Why does my G16 gas golf cart whines when the accelerator is pressed down but will eventually start after pressing it 4 or 5 times and it seems to help somewhat if I press it at the top which is odd???
yamaha g16 gas golf cart
time for a service and cant be ignored
something not right between pedal and drive wheels
if pedal has to be pressed like that
Jun 08, 2016 | Cars & Trucks
What button to I press to fold the handle of the cart into the body.
Took me awhile to figure this out too. Very simple: the upper handle of the cart is 'locked' into place with the lower cart just above the upper bag strap. It's the same plastic piece that adjusts the angle/position of the handle. Slide this plastic piece back up the shaft (toward the ball holders), and the upper handle will release & fold down. The 2 side wheels also fold in at the same time.
Mar 09, 2014 | Caddytek CaddyLite 11.5 v2 Deluxe Push...
How do I align the front wheel of the Bag Boy DLX push cart?
Unfortunately, there is no adjustment on the wheels of the DLX. However, you can often adjust it's alignment by ensuring that the weight of the golf bag is properly centered on the cart.
Aug 17, 2013 | Bag Boy Bagboy Express DLX Push Carts
I can't fold my caddytek lite 11.5 v2 cart
I'm sure you figured this out by now, but for others stuck with the same question, here's how you fold it: the upper handle of the cart is 'locked' into place with the lower cart just above the upper bag strap. It's the same plastic piece that adjusts the angle/position of the handle. Slide this plastic piece back up the shaft (toward the ball holders), and the upper handle will release & fold down. The 2 side wheels also fold in at the same time.
Jan 21, 2013 | Caddytek CaddyLite 11.5 v2 Deluxe Push...
I am not sure if the wheel bearing on the front end is broke. it makes a loud poping noise when turning and the wheel is towed in
Loud popping/grinding most noticeably heard when turning is normally a sign of a bad CV joint. Look under the van where the axle half-shafts come out of the transaxle and connect to the backside of the wheel assembly. Are the rubber boots on the axles torn or missing?
If you hear the popping only in left turns, your right CV joint is bad, If you hear the popping only in right turns, your left CV joint is bad.
Nov 10, 2009 | 1999 Ford Windstar
My ps3 won't take the disc it is like there is a lever in the way what do i do?
did you take the drive apart with a disc in it?
There are 2 little white "bars" that pop up when the disc is inserted most the time this happens when a drive is taken apart with a disc still in it and its not in the ejected state.
if you didnt take it apart then there is prolly a cd in there still and there is a problem ejecting, if you did take it apart here is how to reset everything to the right working state. sorry if its hard to follow.
to get it back to normal you need to reset it, if its under warrenty send it in cause the only way to fix this is by taking apart the ps3 and and the blu ray drive.
ussually this happens when a drive is taken apart with cd in and you remove the loading gears cover(the black piece with the levers and the wheels) off.
when you put this cover back on you need to make sure that the wheels are open all the way --- right wheels up and to the right, ..left wheels up and to the left. When its open like that you can see the gaps where those little white bars fit into just put it back on with it open and the bars in the gaps.
usually your looking at more steps though because the rest of the hinges on the lid wont line up. you can try to put the cover back on and eject and try loading an old or blank cd, blank because if something is off it may scratch it.
see if everything works.
if not you need to re-align everything to be in the ejected state. to do that you have to manually move the long black piece on the left side of the drive(with the cd inserting side facing you) and firmly but carefully push it twards the back of the drive and the laser should lower. it may make a poping noise if you go to far but should be fine its just the piece going to far out and poping off the gear. to test it push the cd guide wheels open and it should raise the laser and you can now lower it using the eject button. if it doesnt and you just hear a spinning gear gently nudge that long black piece on the left that you pulled back earlier towards the center of the drive and it should catch itself. after every thing raises and lowers fine make sure its in the ejected state and put the cover back on. should work now.
Sep 24, 2009 | Sony Playstation 3 (PS3) Console
Golf Logo
338 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
