Washing Machines Logo
G
Graeme Fuller Posted on Sep 15, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hoover 750L top loading washing machine won't drain water. Broke down this morning (Saturday). Can't get anyone to come out until Monday. Live in Kardinya, WA.
Bill Boyd
Level 3:
Top Expert:
  • Hoover Master 53,816 Answers
  • Posted on Sep 15, 2018
Bill Boyd
Hoover Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925636
Points
172802
Lower the drain hose past the tub level and the water will drain out
if inside use a bucket to collect the water
when empty switch off the taps and use the spin cycle to dry the clothes
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on May 04, 2007
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Anonymous
  • 1673 Answers
  • Posted on Jan 18, 2008
SOURCE: hoover 500 top load washing machine - water in-flow very, very slow
Check the water valve. Most of the hoses that are hooked to the water valve have a screened filter, turn water off, unhook hoses, check to see if they need to be cleaned. Other wise the water valve is bad and will have to be replaced.
Anonymous
  • Posted on Jan 03, 2009
SOURCE: hoover 750L top loader washing machine
I had this problem. I alternated the hot and cold water valves (changing over the wiring) and then hot tap then dribbled instead of the cold. Replacement part i believe is around $35AU
Anonymous
  • 1122 Answers
  • Posted on Apr 24, 2009
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
beltronic205
Gerry Harvey
  • 1482 Answers
  • Posted on Mar 31, 2010
SOURCE: I have a Hoover 750L washing machine and it is not
is this not spinning due to not pumping out water/..if so clean drain pump/check filter.this should fix
1helpful
My Hoover 750L starts its spin cycle but when goes to a really high spin it makes a noise.
Check your mounts and support springs---one of them maybe broke or loose---since you haven't described the noise this is the best i can come up with. GL
Hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
My hoover washing machine top load won't start. I have checked the power from the wire going to the timer.The door latch switch is working and still it won't start.
my hoover washing machine do not stop they show 1 min left . i was try serval time the happend is same and inside few water as well
750L 1AUS top loader Hoover washing machine washes (agitates) and rinses but will not spin. Can hear the sound of the pump
First unplug the machne,there are 3 wires that goes to the motor,put the machine on its side and inspect that none of them have a break or came loose from its wire terminal.Good luck Giselle Dosen,have a great day !
Washer drains and will not spin
GE Answer Center®
1-800-626-2005
Monday - Friday: 8 a.m. - 10 p.m. ET
Saturday: 8 a.m. - 7 p.m. ET
Closed Sunday.
Be sure to check the MODEL # and SERIAL # on your machine BEFORE CALLING. Good luck
4helpful
2answers
I have a Hoover 750L washing machine and it is not spinning now in the washing circle so the clothes are soaky wet. How can I fix this problem
Hoover washing machine model HNF71683D not draining water
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Describe your hoover 750 l Top Load Washer Problem. We got a hoover 750l washing machine. There is constantly a loud scraping noise if the machine is switched on. I tried to get the S/S bowl out, only on...
Behind the control panel is your service manual.
The instructions are there.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
2answers
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
