Question about Golf
2013 Club car xrt 1550 ...installed everything new on the parking brakes but still won’t hold. What am I doing wrong? Thanks Dennis
Posted by Dennis Loftis on
Bill Boyd
    Top Expert:
  • 53,816 Answers
Not adjusting the brakes up properly
Posted on Sep 15, 2018
5 Related Answers
Anonymous
  • 195 Answers
SOURCE: parking brake pedal goes to floor
Hello;
The parking brake cables may be stretched and in need of adjustment. Follow the cables along to a nut. Then you can tighten the adjusters up on both sides until you have the proper tension. Also make certain none of the brackets are bent or broken that the cables ride through.
Thanks;
RPM Northwest
Posted on Jan 19, 2009
Anonymous
  • 164 Answers
SOURCE: parking light brake light will not go off after power is engaged
no the P light ans system will always be on unless you command a drive or N funtion since there is no 'park' in the drive train only a mechanical brake. when running/on, when you put in drive it should acknoledge drive and P should unlock. if not you have trouble and need the dealer
Posted on Sep 02, 2009
Testimonial: "this was very helpful. Thanks. It finally went into drive after repeated tries. Good to know there is no actual nonmechanical parking brak"
isaid
mike james
  • 302 Answers
SOURCE: Parking brake not holding
it sounds like its time to replace ur rear brakes, but dont forget to readjust handbrake when done
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_00678fd4800d19c5
Posted on Oct 03, 2009
nvannoy
nvannoy
  • 234 Answers
SOURCE: parking brake on my 01 kia rio(standard) no longer holds
You may want to revisit those rear brakes to make sure the parking brake linkage is hooked up properly. There is usually a spring that needs to go over the parking brake linkage and make sure the cross bar is facing the right direction and holds both the shoes and the parking brake linkage.
Posted on Jan 06, 2010
trevor wright
  • 16 Answers
SOURCE: replaced rear brakes, and the new rear brake drum
No, just back off the adjusters completely before putting on the drums.
Posted on Jun 03, 2011
Club car xrt 1550
This section is for car and truck question, we have no info on this type of conveyence
Jun 02, 2013 | Cars & Trucks
Craftsman lawn tractor parking brake won't engage
are you holding the lever while lifting your foot of the pedal?
Jun 27, 2012 | Garden
Need to replace rear brake discs and pads
YOU NEED TO REMOVE THE REAR WHEELS.REMOVE PARKING BRAKE CABLE CLIP FROM CALIPER DISCONNECT PARKING BRAKE CABLE.HOLD THE GUIDE PIN WITH A BACK UP WRENCH AND REMOVE UPPER MOUNTING BOLT FROM THE BRAKE CALIPER.SWING THE CALIPER DOWNWARD AND REMOVE THE BRAKE PADS.TO INSTALL NEW PADS.YOU HAVE TO RETRACT PISTON INTO THE HOUSING BY ROTATING THE PISTON CLOCKWISE.PUT EVERYTHING BACK VISA VERSA.
Feb 24, 2010 | 2002 Jaguar X-Type
I need to know how to properly install a new park brake cable on a 1995 f150 st.six 4.9efi. I got the new cables and installed them but the new front and intermediate cables won't reach the bracket holding...
The adjustment would be on the cable themselves. They should be full extended before inserting them. For a free full online repair manual for your truck, go to autozone.com, register for free and view your repair manual
Jul 21, 2009 | 1995 Ford F150 Styleside Regular Cab
2004 Mercury Mountaineer Emergency Brake Adjustment
Greetings larslabs,
My name is Dennis and I can assist you to finding your parking brake adjustment location.
1) the adjustment is located so that you have to remove your center console floor finish panel (this is the drink holder).
2) raise your parking brake lever and gently pry the plastic tabs from the center console.
3) Once you can see the park brake lever you will see a nut that is turned to adjust the lever so that it has 5 clicks when it is applied.
Glad to be of assistance and thank you for using FixYa. Please rate the solution because I can learn from your rating (and it keeps my rating up to date). Thank you, Dennis
Nov 16, 2008 | 2003 Mercury Mountaineer
Golf Logo
470 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
