MANUAL PROGRAM CODE SEARCH YOUR XR11 REMOTE TO YOUR TV:
1 – Turn ON the TV you will be using with the XR11 remote.
2 – PRESS AND HOLD the SETUP button (bottom left) on your XR11 remote until the LED status light (top of remote) flashes from Green to Red.
3 – Begin manual TV code search by entering 991 on the XR11 remote.
4 – The LED status light will flash Green 2 times.
5 – Repeatedly press the CHANNEL UP button on the XR11 remote to search through the TV codes.
6 – Keep pressing CHANNEL UP button on the XR11 remote until the TV you are programming turns OFF.
7 – After your TV turns OFF press SETUP.
8 – The LED status light on your remote should flash Green 2 times.
9 – Press the TV Power button on the XR11 remote and if the TV turns ON, your XR11 remote is programmed.
Be sure to hold the SETUP button until it flashes Green 2 times after your TV turns OFF.
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
SOURCE: just bought a ONN LCD TELIVISION MODEL AO37ZID from asda, looking for a 4 digit code for sky remote
Got this one to work on both the 37" AO37ZID and the smaller 17" Onn branded A017LC
Sky code: 0527
SOURCE: codes for my sons TV
Hi there i also had this problem with my "onn" television and there isnt an "onn" make - apparantly it is the same as pacific or schneider so if you get a remote from asda theyre really cheap less than a tenner - i found that look up either schneider or pacific and the first code it says should work for your tv!hope this helps!
SOURCE: sylvania LC321SS9 remote code
I have the sylvania LC321SS9 tv and a atlas dvr1056 remote code 1864 works great with all functions!
SOURCE: remote control code for ONN tv, Model- LE 19L`cdd-vd0701`
Flat Panel Televisions I HAVE A SKY+ BOX AND NEED A Remote control code for ONN tv, Model- LE19LCD0801
