Measuring Tools & Sensors Logo
Ken Leduc Posted on Sep 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 10 hp gas motor with no spark. need help. It is a briggs and stratton
Seth Ettleman
Level 2:
Habit-Forming:
  • Expert 91 Answers
  • Posted on Apr 09, 2019
Seth Ettleman
Expert
Level 2:
Habit-Forming:
Answers
91
Questions
0
Helped
37364
Points
265
If no spark after new plug, check your kill switch for proper function, if that is working correctly you will need to check the pick up coil and gap on flywheel. Check your plug wire also for continuity in case of faulty wire.
Spark is pretty simple to get back most of the time, just dont want to start swapping parts for no reason.
Macophile
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 19 Answers
  • Posted on Mar 24, 2019
Macophile
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
19
Questions
0
Helped
5466
Points
44
Change the spark plug for a new clean one. Make sure you are using the correct gas/oil mixture.
5 Related Answers
Anonymous
  • 35 Answers
  • Posted on Apr 19, 2009
SOURCE: briggs & stratton 3 hp engine will not start
likely needs a carb kit
logi_345
  • 7 Answers
  • Posted on May 02, 2009
SOURCE: 5 HP Briggs and Stratton Engine
Take the coil off clean with sand paper then get a piece of cardboard from a cereal box or cigarette box, put the piece of cardboard in between the coil and the magnetic strip on the flywheel ''believe it or not it is the perfect gap'' 'let the magnet pull the two together'' then tighten the coil down. if still no spark get a new coil.
roeb
  • 819 Answers
  • Posted on May 05, 2009
SOURCE: 10 HP Briggs and Stratton Throttle assembly
www.briggsandstratton.com/maint_repair/manual_and_more/
Then print in model no etc. You should get owners manual as well as parts list.
Anonymous
  • 86 Answers
  • Posted on May 12, 2009
SOURCE: gas comes out of spark plug hole
You have a Float problem you also make have gas in oil.
Anonymous
  • Posted on Dec 02, 2009
SOURCE: need point gap setting for 8 hp Briggs and
need coil gap setting for 2-8 hp briggs stratton
18 hp briggs and stratton no spark
unplug oil senso still no spark un \plug shutoff wire to coil still no spark replace coil
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
5 h.p. briggs and stratton outboard motor shuts off
This has puzzled me a few times in the past. It is most likely related to a fuel issue. If you have an external tank, make sure there is no debris or water in the bottom (looks like a big bubble under the gas), next I would check to make sure the fuel lines are not cracked allowing air to enter. This could also be caused by a bad o-ring at the connector on the fuel tank or motor or the connector is not securely connected.
Top HP Measuring Tools & Sensors Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a HP Measuring Tool and Sensor Expert? Answer questions, earn points and help others
