joao nalito uagumana Posted on Sep 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Como resolver erro c6102 bizhub 363 - Konica Minolta Office Equipment & Supplies
NAJI AZAR
Level 2:
Habit-Forming:
Scholar:
  • Konica Minolta Expert 94 Answers
  • Posted on Sep 24, 2018
NAJI AZAR
Level 2:
Habit-Forming:
Scholar:
Answers
94
Questions
7
Helped
104816
Points
206
C6102 Drive system home sensor malfunction
• The scanner home sensor is unable to detect the scanner located at its home position.
• The scanner home sensor is unable to detect a scanner even when the scanner motor has been driven to move the scanner over the maximum traveling distance.
• The scanner home sensor detects the scanner when the scanner has moved the maximum traveling distance from the position, at which it blocks the scanner home sensor.
5 Related Answers
Anonymous
  • Posted on Sep 15, 2008
SOURCE: Erro D: 5f08 5e02 Olympus Stylus 700 como resolver?
I don't have a solution we bought another camera. but our 710 is not very old and would like to get thisone fixed but will not pay $100 just to get it checked
Anonymous
  • 1566 Answers
  • Posted on Feb 09, 2010
SOURCE: error LSU
The LSU error stands for Laser Scanner Unit error. The probable cause/s:
The Polygon motor in the LSU does not rotate.
The LSU’s laser beam is functioning properly.
What you can do:
Try to unplug the machine for a couple of minutes or maybe a little longer and then plug everything back in. Power on and then test.
Anonymous
  • 32 Answers
  • Posted on May 08, 2010
SOURCE: tenhouma copiadora gestetner dsm 715 mostra erro
Exposure lamp defective
Exposure stabilizer defective
conection lose
ditry scanner mirrors or out of position
lense block out or position
hope it helps dont understand the languege
Anonymous
  • 44 Answers
  • Posted on Sep 06, 2010
SOURCE: como vou resolver o erro
Its a fuser code. To reset it the code and get it to work again.
1)Turn the main power off ( the switch behind the toner door )
2)Hold down the Utility button while you turn the machine back on.
3)Keep holding till you see "Trouble reset"
4) Push trouble reset then turn off and on the machine and will start working
Anonymous
  • Posted on Oct 01, 2010
SOURCE: COMO FAÇO PARA RESOLVER ESSE
i have this error 0xc05d0281 em hp photosmart 3313 all-in-one.
what can i do?
Erroe code 0202
open the 1st draw check for paper behind the draw THEN REMOVE THE PAPER ON THE LEFT SIDE OF THE DRAW NOT A STORAGE AREA ITS FOR 11 x 17 PAPER!!!!! if the code comes back burn out the motor or worse damage the control board and the motor get a tech out to look at it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Bizhub 363 error code c-fa16
MFPB board, but might try having a tech come and reflash the copier operating system software
Sc 878 error how can i resolve it Sc 878 erro como posso resolver
Bad controller board (where the print cable plugs in) try reseating
1helpful
Riso RZ200ep. como resolver o erro codigo A - 06 -403
Konica minolta bizhub 363 error message c-2201
remove the toner bottle let machine thur its paces when it says install toner bottle install correctly
5helpful
Como vou resolver o erro C 3423 da Konica Minolta bizhub c253
1helpful
Erro D: 5f08 5e02 Olympus Stylus 700 como resolver? Ao Ligar a camera, a lente fica desfocada e logo em seguida aparece o erro acima descrito.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
