I had one channel repaired, it comes on now , but I cant get any sound out of it
SOURCE: Denon AVR-681 receiver
this manual is the same as the 681 the only difference is the front input and power difference. this web sight http://www.usa.denon.com/AVR1602_682_ownersmanual.pdf
SOURCE: No sound on cable TV for Denon AVR 1905 Receiver
Audio setup on the TV, needs to be swited to Fixed or both, this is usually the same on all T.V.s....
SOURCE: Also problem with Denon AVR-2802
If DIGITAL sign on the display blink, it mean the DSP board is defective. probably the DSP itself
SOURCE: No sound/test tone front front right channel
1-make a reset to your system.2-repeat your speaker setup.3-confirm that you assign your sysem for 5 chanell surround system.-4-change the cables between left and right front speakers if the trouble go to left channel you will have a problem in receiver itself-if the problem exict you will have a problem in speaker itself(cable or speaker)
SOURCE: Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers.
