Question about Hitachi Televison & Video
Hitachi 53sbx59b got red power light no picture no sound
Posted by Bob Caswell on
Chris Harding
    Habit-Forming:
    New Friend:
  • 30 Answers
Just need to know if you have tried this or cab you try control switch on the TV, Changed batteries, remote camera test and another socket?
Posted on Sep 13, 2018
5 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: Hitachi 53uwx10ba no sound/picture flashing power light cricket sound
Possible shorted cap C702 ? Open E994 pico fuse.....check
carefully with ohmmeter...all fuses and let me know.....T.
Posted on Mar 05, 2008
jhinsincity
Julio Hernandez
  • 616 Answers
SOURCE: Hitachi Plasma P50S601 no picture sound OK
probably needs new scan drive board along with upper and lower buffer boards. it wont be cheap and its best to have a tv shop do it.
Posted on Aug 30, 2009
Anonymous
  • 61 Answers
SOURCE: power surge-no picture or sound, just red blinking power light
Any malfunction associated with a blinking redlight usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Posted on Sep 13, 2009
Ecollier2012
Edward
  • 3459 Answers
SOURCE: i have a hitachi 53sbx59b 53in tv
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Sep 27, 2009
ladywinn
ladywinn
  • 5138 Answers
SOURCE: hi my hitachi 61sdx01b red power light is working
CK fuse F903 if it blows it again then replace STRM6511 CK all of the pico fuses 5and 6 amps they look like resistors they willbe green or yellow they are fuses.
Posted on Dec 21, 2009
No picture
OK, the set is on if get the menu display and you have sound--either a video circuit problem or a glitch.
Do you get picture via the rear audio and video input jacks? this will rule some things out.
Also if not tried disconnect set, any box used, or a receiver from power for several minutes and power back (possible glitch).
Dec 21, 2012 | Hitachi 53SBX59B 53" Rear Projection...
I have a 53" Hitachi Rear Projection TV, Everything works except the color. The 3 color projection lamps are functioning and all of the tv's focusing features appear to be functioning as well. It has a...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 14, 2010 | Hitachi 53SBX59B 53" Rear Projection...
My mirror is broke in my big screen do you have to buy a special mirror or can you use any mirror?
The mirrors are specific to the unit as they have slight curves to bend the picture correctly so it aligns to the screen properly. To ensure you get the correct picture for your unit, you would have to order the manufactures original replacement part. You can order an new OEM replacement mirror for this model (53SBX59B) from a major Hitachi parts distributor at the link below:
Hitachi 53SBX59B Replacement Part Mirror / 53" Inner Mirror
Apr 13, 2009 | Hitachi 53SBX59B 53" Rear Projection...
HITACHI 53SBX59B, projection lights don't line up.
You need to have the covergence adjusted.  Consult user manual for instructions on how or have a professional do it for you.
Jan 04, 2009 | Sprint Hitachi P300 Cellular Phone
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Projection lights don't line up
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Digital Compatibility
TVs, VCRs, DVD players, camcorders and video games will continue to work, even if they are only analog-capable. Such equipment, however, may not provide digital-quality picture and sound.
Hope this helps.
Feb 16, 2008 | Hitachi 53SBX59B 53" Rear Projection...
Picture flickers when T.V. is tapped on or struck.
sounds very much like a loose connection, i.e. a wire or solder joint, you could have a look around make sure everything is plugged in right, as for the solder joints id advise getting it proffessionally looked at as these rear projection tvs can be a lot of hassle if you slighty knock any of the 3 tubes,
Feb 25, 2007 | Hitachi 53SBX59B 53" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
