Question about Vision Televison & Video
Hello, I have a Komz Baigish 6u. I have a problem with the power supply and I don't know if it is due to the 9V battery or just to the internal power supply. With some 9V batteries the vision goes irregularly and then goes off while other batteries do not turn on. What do you suggest? Do you know where I can find a Komz replacement power supply? Thank you for the help. Best regards
Posted by Patrice on
ASDA durabrand radio model no. LEDAB0701 information bar has stopped working
Hi - As per original question, NOT A TV, the LEDAB0701 is an ASDA Durabrand DAB Radio, so no remote! Just hit this problem - and found a work-around. Sound always worked - display and backlight failed. Could not spring radio apart - as well as the screw in the battery compartment - there seems an anchor the other end that defeated me. I run off the supplied Power supply and rechargeable batteries. The batteries ran down and I plugged the psu and display came back - for a few minutes! The sealed Power Supply unit (psu) is probably unregulated non-switched mode type. It gave 15.6v unloaded. Unregulated psu's normally run 1.4x nominal voltage with no load and are pulled down to the nominal voltage as the load current is taken (i.e. ASDA psu should have been 9v x1.4 =12.6v not 15.6v).
Seems the radio is sensitive to high psu voltage as when I ran off a regulated psu - problem partly went away. Regulated means you get whatever voltage you set whether no load, half load or full rated load.
Also once switched off fault appears the internal batteries were keeping the display off setting. I used a 12v 1A variable regulated psu. It has 9v, 6v, 5v settings. 5v is too low. 6v works when already running but it needs 9v to start. However the problem is that the display will still switch off if I run for a long time on 9v, so I have to switch down to 6v. Alternative, start on battery and plug in 6v works [6xAA=7.2v nominal, range: 8.5v down to 6v]. Seems some internal components of radio or psu have drifted/become faulty.
You need a positive center/hole polarity. Ideally aim at 500mA or greater replacement psu. Ideally use a variable one so it can be used for other things if your problem is different and this is not the solution. If you have an unregulated variable psu (400mA or greater) try running at 6v (will be higher but perhaps not too high) then switch to 4.5v or 5v (again will be 1.4x higher) but make sure it is set to positive centre/hole.
Apr 12, 2014 | Televison & Video
I need to install a 9v battery in my Kenmore Elite upright freezer and I don't know where the battery compartment is.
Please expalin to me what this battery powers, i have been a appliance repair technician for over 30 years and have NEVER seen a battery used to power any component, i know manufactures come out with new stuff all the time so i would like to know what this battery does
Jul 23, 2011 | Kenmore 20.6 cu. ft. Upright Freezer 24092
I need a Adapter but don't know its voltage and current?
Hello
You need and adapter with following specifications for your DVD player.
Power Source . . . . . . . . . . . . AC 100~230V, 50/60Hz
DC Output . . . . . . . . . . . . . . . . . . . . . . . . DC 9V, 2.2A
OK
May 15, 2011 | Cyberhome CH-LDV 712 Portable DVD Player
Baigish 6U Night Vision Monoculars are out of focus
Would you be this hardware vendor and if so at what price ? Contact : [email protected] Thanks.
Oct 18, 2010 | Kalinka Baigish 12 Russian Night Vision...
Wont turn on red power light blinks 10 times
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help out in solving the problem, take care
Oct 03, 2010 | Panasonic Televison & Video
V705 not working due to plugging in a 9v charger.
the battery may be fine. but I think you might have fried the internal power port on the camera. Best bet is to see if Kodak can replace it or fix it for you. You will need replacement parts for this problem
Oct 09, 2009 | Kodak EasyShare V705 Digital Camera
9V color wire
Red +, Black -
Aug 21, 2009 | Computers & Internet
How do I replace the battery on Baigish 12 night vision binocs?
Go to; www.rugift.com. They are a dealer for this NV and they do have the user manuals.
Good luck. :)
Mar 11, 2009 | Kalinka Baigish 12 Russian Night Vision...
Illumination
one tube has gone faulty and acts like short on high voltage power supply causeing both sides not to work tubes have to be removed and tested one at a time and faulty tube replaced
wayne
Jan 27, 2008 | Kalinka Baigish 21 Russian Night Vision...
Televison & Video Logo
88 people viewed this question
Top Vision Televison & Video Experts
Marvin
Marvin
ray gallant
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
