Question about SanDisk Sansa Clip MP3 Player
MP3 Wont charge or upload
My MP3 charger cord seems to be working incorrectly. It can be connected to any computer for hours, and not even say its charging. It actually seems to be losing power when it charges It also wont upolad anything new. I've been trying to find a new cord, but I lost my receipt awhile ago. What could be the problem?? And how do I get a new charger cord????
Posted by mz_e_hejtman on
IT Solution
  • 805 Answers
U need a new cord for charging.u lost ur receipt so no problem u can buy it any electronic or computer market i hope.
Posted on Aug 03, 2009
Anonymous
  • 4 Answers
Cut any charger chord or any type of usb wire
We got a RULU in 12/2013. It worked for 3 months and now can not charge i
Some tablet brands will not recognize certain charger brands or connections.
First, try all available connections-USB-wall inverter, and direct computer connection (making sure the computer is awake and logged in). Second, try restarting your tablet. Third, try gently wiggling the connections on both ends, to see if it recognizes a charge. Finally, leave it plugged in for a few hours, even if it says it isn't charging. You may have a trickle charge-to put it simply, the cord is not giving the device enough power to qualify as a charge, but there is power traveling through the cord. If the charge level goes up a little over that time span, you have a trickle.
If these don't work, just purchase a new charger. They're sold everywhere-Wal-Mart, Target, Best Buy, 7-Eleven, name a store and they probably sell USB charger cords.
I hope I helped.
Jul 08, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Icoustic mp3 player wont turn on even though it is fully charged
Try to check power cord or else try to check your power switch.
Oct 09, 2017 | Audio Players & Recorders
Hi i have an alba MP2200BUK mp3 player.. how do i charge it? When do i know that the mp3 player is charged?
connect the usb cord you received with the device to the device and to your computer and it will charge automatically. generally you want to charge a device for several hours at least, most devices will let you know when they are done charging.
Feb 15, 2011 | Audio Players & Recorders
Eclipse MP3 Player- Wont charge. I plug it in and it shows the hourglass then it will show a computer connecting/connected to a battery but it will not charge
People on other posts said to get a wall charger and that'll work. We looked for one, but couldn't find one. We ended up using a usb camera upload cord that had the same connector. It charged just fine after that. We have a 180 Eclipse mp3 player...I'm guessing the cord connectors are pretty universal.
Mar 14, 2010 | Eclipse CLD2 MP3 Player
Eclipse MP3 Player- Wont charge. I plug it in and it shows the hourglass then it will show a computer connecting/connected to a battery but it will not charge. i'm using a laptop, could that be the...
The official unofficial REAL Answer is here!!
I swore it off as Junk untill I took the time to figure this out.
When charging the power swith needs to be in the "ON" position.
Charge for around 3-5 hrs.
To turn device ON You hold down the Play/Pause button for quite some time, (much more time than expected from other players,cellphones or devices) the unit should power up and display "ECLIPSE".
I thought I was "taken" and strange when I saw the link for Qresolve within the files of something that did not work.
Theres even an EQ feature in the Menu and the sound is pretty decent. Good Luck!
Mar 05, 2010 | Eclipse CLD2 MP3 Player
I have ipod nano 1st gen and my ipod wont detect by itunes even my explorer using USB 2.0, i have firewire port wall charger when i try to plug it it charge but idont know if it will work to computer cause...
There might be a few issues here:
1. Your ipod software needs to be updated
2. Your usb cord is bad
3. Your usb port is not working properly
Either find someone that has a firewire port and update it via itunes, or use someone elses computer to update your ipod's software.
www.huskyipodrepair.com
http://repair-scratched-ipods.blogspot.com
Jan 26, 2010 | Apple iPod nano
I can see the songs on my computer that I have uploaded onto my SanDisk and I can also add new music as well, But the system will not charge and when I connect it to the USB cord it says connected but it...
ensure the unit is chargeable using usb data cable, usb charger has only 2 out of 4 wires connected to the charger whereas when the cable is used as data cable all the 4 wires are connected and the device acts as a usb device, this may block the charging of the device due to internal circuit design within the device.
Oct 08, 2009 | SanDisk Sansa Clip MP3 Player
Y wont the razor phone charger charge my MP3
Well it wont be compatible with the mp3. even if it does seem to fit into the slot where it charges you still wont get it to charge. also different chargers deliver a different ammount of energy to the device so it either wouldnt be enough or it would be too much. I hope this helps you solve your problem.
Feb 28, 2009 | Philips GoGear SA3125/37 MP3 Player
It dosent even charge!!
Are you sure it's not charging? What makes you think it's not charging? When you plug the USB cord in (and it's attached to the charger or the PC)a screen should appear temporarily. It shows a picture of a PC with a usb cable coming out of it. Are you not even seeing that much? Remember that this is a no-name Chinese player, so don't expect iPod or iRiver quality. I didn't think mine turned on, but that's because the on/off switch was sticky and because you need to press play once or twice after it's turned on to get it to do anything. But so far, mine's working fine.
Aug 21, 2007 | Kaser Corporation Mambo Mano Digital Media...
SanDisk Sansa Clip MP3 Player Logo
385 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
