Question about Frigidaire Dishwashers
Our Frigidaire dishwasher only partially drains. Seems like there’s is air in the drain system
Posted by Kate Holbrook on
5 Related Answers
Anonymous
  • 173 Answers
SOURCE: dishwasher does not drain in normal cycle. on
Thoroughly clean drain screen and drain. Add small amount of drain cleaner to drain, flush after five minutes. Do not add hot water with drain cleaner.
Posted on Jul 08, 2009
Anonymous
  • 51 Answers
SOURCE: Frigidaire Dishwasher won't drain
Try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Posted on Jul 15, 2009
Anonymous
SOURCE: dishwasher not draining completely
I was having the same problem with water sitting at the bottom of my dish washer. I had recently installed a new garbage disposal when the problem started. You need to make sure that you knock out the inlet valve where the disposal drain line hooks up. If you have never hooked up a washer to your disposal, this piece will be in place. Stick a flat head screwdriver in where the drain hooks up and hit it with a hammer and the small plastic circle will pop out. The washer does not use any water when that is blocked and therefore will leave the old water to turn rancid...I hope this helps!
Posted on Sep 05, 2009
sclarke7
Steven Clarke
  • 222 Answers
SOURCE: air gap valve leak for dishwasher
remove the entire drain hose from the air gap and be sure it is clear, also the dishwasher drain should be going to your disposal, if you chose to use the air gap it should be connected from d/w to air gap then to disposal, todays dishwashers dont need an air gap.
Posted on Sep 12, 2009
Anonymous
  • 1531 Answers
SOURCE: MY FRIGIDAIRE DISHWASHER WILL NOT DRAIN. MOTOR
if there is still water in the dishwasher take the drain hose off from under the sink and use a large pot or mop bucket and but the unit into a drain mode usually by cancelling the wash cycle if the unit still does not drain.Then use a wet dry shop vac and attach it to the end of the drain hose to remove the water
after the water is gone check the drain pump for any kind of obstructions you may need to replace the drain pump
Posted on Jun 06, 2010
Water did not drain from the bottom
Hello Cheryl, There are a couple of possibilities. When the dishwasher drains the dirty water it is a time based function. This leads me to believe it is a blockage or partial blockage in the drain hose.
Here is an example. (If your dishwasher drains into your garbage disposal) washing dishes you put scraps into the disposal and forget to turn it on after you are done. The disposal is filled with scraps this restricts the flow of dirty waterfrom the dishwasher. If the flow is restricted less water is being drained per second from the dishwasher. This is why the dishes still looked clean and there was still water in the bottom of the dishwasher.
(if your dishwasher drains into a drain pipe) there is blockage or partial blockagein the dishwasher drain hose. if the sink drains slowly the blockage is in the main line
Hope this helps
Joe Connolly
Nov 02, 2011 | Frigidaire Dishwashers
Frigidaire dishwasher has standing water that did not drain
Frigidaire dishwashers have two pumps. one for wash and one for drain. But if your
dishwasher is connected to a garbage disposal and the disposal is not working then the
dishwasher will not drain. Otherwise the drain pump on the dishwasher has failed
OR the line itself is plugged (sometimes the port on the disposal gets gunked up and
will not allow draining). If you have replaced the disposal recently
the "knockout" may still be in the garbage disposal port.
One last thought, if you have
a small tomato paste can sized item next to the faucet that seems to serve no
purpose, this is called an "air gap". They can also get gunked up as well and prevent
draining of the dishwasher. They are inexpensive to replace or can be cleaned.
Hope this is helpful.
Apr 12, 2011 | Dishwashers
The auto drainage isn't working properly
You will need to check the drain hose to make sure that you don't have a partial blockage. If you have an air gap check that to make sure it is not partially stopped up. If you don't have an air gap check to make sure your drain hose is not lower than your sink drain allowing water from the sink to drain back into the dishwasher.
Jul 14, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Fridgidair Dishwasher takes long time to run
ok with the soap prime the sink before you start it and clean the dish washer.take a table sppon full of tang put it the dispencer and run the unit this will clean the unit
Apr 25, 2010 | Dishwashers
Dishwasher does not drain completely
Check your main drain system where your finally connect to let off the dish washer water.
Apr 10, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Water is sitting at bottum of dishwasher not draining very well and not washing well
you most likely have a partial blockage in the drain pump or the drain line that goes from the floor of the dishwasher to the sink drain. Disconnect those parts and look. remove whatever the block age is.
Jul 11, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Jenn Air DW961UQW Partially Fills, Drains and Done
is there a diagram of how to replace pump in the jenn=air dishwasher model dw961uqw?? If so is there aweb site I could look at? Thanks Ida Vogegelgsang
May 31, 2008 | Jenn-Air 24 in. DW961 Built-in Dishwasher
Abnormal noise and vibration
pump is viabrating against body remove frond base and separate metals or slip a bit of foam between
should fix problem
oterwise there may be obstuction in drain pump
Feb 23, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Dishasher does not drain
If it gravity drains, but the pump does not push out the water.......replace the drain pump. I just repaired an 8-year-old  Frigidaire dishwasher with this very problem, and although it sounded like the pump was operating, it was not....it was just vibrating. I replaced the drain pump and it now works perfectly. I am a service tech with 38 years experience.
Jun 21, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
