Sharp Carousel Convection Microwave Model R8320E Serial 30912813 50 Hz 1.6 kW 220V Input Current 6.3 Output Power 650 W Frequency 2450MHz heating element 1.5 kW
SOURCE: Where is the light bulb in an old Sharp Carousel Microwave?
Microwave_svc's site is awesome! I was able to get all the help I needed for a similar Sharp Carousel microwave. My bulb was simply loose in the socket base causing intermittent bulb lighting. Microwave_svc's helpful links got me to the service manual and, along with a nice set of "tamper-proof" screw compatible TORX bits I bought at HarborFreight, I was easily able to get cover off, remove bulb socket, tighten bulb, re-install bulb socket, button unit back up, and, voila, the light now works without intermittent blinking. FIXYA!!!!
Many thanks to guru microwave_svc!!!!!!!
SOURCE: Looking for instruction manual Sharp \carousel
if you google the model number and the brand you should be listed with a series of sites that supply manuals, service manuals, etc.
SOURCE: Sharp model R-1871 shuts off every 59 seconds
This
is a problem in one of the damper-related components, either the switch
or motor or the damper door may be binding.
The
damper is a door inside that opens or closes depending on cooking mode.
If the controller senses that the door is not in the right position, it
will shut down the cook cycle.
Sharp models stop after
59 seconds.
See the attached sample
drawing for a typical damper assembly.
We have the applicable
service manuals for these models and have uploaded it to our site here and here to help you.
If a switch is all you
need, we offer a universal type for only $5 postpaid which you can
order here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Testimonial: "traced to motor for damper. Would not have had a clue without this information provided by fixya"
SOURCE: sharp microwave stopped working
Is it totally dead? No display? Or just does not cook? If it made an unusual noise before it 'died' something probably shorted out.... You need an ohm meter to troubleshoot. If the fuse is open, switches and HV circuit need to be checked before replacing fuse. Sometimes on the convection Microwaves (not just Sharp) the fuse will 'rust' and open rather than blow. Or the fuse holder can over heat and fail.
SOURCE: Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
