SOURCE: Can Denon AVR-1403 take 250 volts AC power?
no it will be damged need hi end monster power strip hd700 or better off ebay that will go 1st and alarm will sound on it
SOURCE: Matrix 5000 ups does not switch over to ac Supply.
Forgive me if you checked this already but make sure that the outlet is live by plugging something else in it. Some outlets can be turned off by light switches.
Once you are certian the outlet is hot then it may be a case of the outlet not delivering enough power. Depending on the UPS you may be able to correct this by decreasing the UPS' sensitivity level. This will prevent it from going to DC power when it detects low voltage from the outlet.
I recommend that you contact the manufacturer or search there website for further troubleshooting information.
I hope this helps.
SOURCE: can't find the dvd to
The Denon Owner's Manual offers some guidance on that.
http://usa.denon.com/us/downloads/pages/instructionmanual.aspx
Key it in, check the 'Search by Text'.
Page 9 lists the various control docks. They have manuals, too.
SOURCE: connect wii to Avr 1312 Denon
What you would have to do is connect the video output of the wii directly to the video input of the bug projector. Also connect the audio cables to it as well. Then connect an audio cable to the projector's audio out or otherwise labeled as "variable out" then connect the other end of that to the matching input terminal, found often labeled as "audio in" on the receiver's grouping of input selections for TV.
Then, on the projector, select the video mode you connected the wii cables to.
SOURCE: NO SOUND FROM 6 MONTH SHARP AQUOS 60" LCD CONNECTED TO DENON AVR 1312
Check to make sure that when you are on that input that HDMI shows up in the front display. If it does not, then you need to turnit on. If it still does not, you could have a problem with your HDMI board on your receiver not recognising the signal.
