SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
SOURCE: Salt tray full of water
Just pour a bag of dishwasher salt in water will come out.Then light goes out.
SOURCE: salt light is on, no manual. What do I do?
Remove the bottom basket from inside the dishwasher - you will see a twist cap on the bottom of the pan - unscrew and add your salt there - it takes about a box to fill. Reinstall cap, and the salt light will extinguish.
SOURCE: refill salt
There is a white plastic circular screw lid in the bottom of the dishwasher washing unit marked salt. Unscrew this and add as much salt as needed so that you can feel it when you put your finger down the hole. This could be quite a bit, perhaps a kilo.
SOURCE: how much salt should you use in a refill of a
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Water hardness is measured in either European °E (clarks) or in the German °dH
( Deutsche Härte) you will find this on all
Bosch Dishwashers here is the comparisons for the two.
If your water is
Very Extremley hard then you will need to program your Bosch dishwasher using the
Code H:06 to
give you maximum protection here is a comparison table for the codes and the Clark and
Normal
0
false
false
false
font-size:10.0pt;
Deutsche Härte with the standard Bosch codes.
Normal
0
false
false
false
font-size:10.0pt;
I suggest that you use Calgon Dishwasher ( Sodium Carbonate
formula Na2CO3.)
tablets in the dishwasher every week this is a brand-named water softner that
is essential to be used in areas of hard water which causes calcification and
catastrophic failure. Use both the salt and the Calgon to suit your hardness.
If you live in a soft water area then set code H:01 as the extra is not required and only use Calgon tablets once a week use normal salt or tablet for the other washes.
Hope this helps
