My dstv in my lounge is working but the second decoder/extrview decoder shows error E48-32,smart card no 10170777014, please help, tv comes on but shows the above error. have unplugged, does not help.
Posted by Charlene Heynes on
5 Related Answers
Anonymous
SOURCE: Bose remote
I need to program the remote to be able to use it with other appliances.
Posted on Aug 14, 2008
Jim Franks
  • 374 Answers
SOURCE: Dish Network "Blue" Smart Card upgrade... Now get only "015"
The solution is usually a simple one and that has been suggested already but I will ask you to try one thing first. Remove the new smartcard and do not put one in. If the receiver still displays a picture and yoou can get to menu 611 run a check switch. After this is performed cancel out of the screens and re insert the new smartcard. Once the system comes back up perform the same steps as you did before with the smart card removed. If this fails you can try the solution they offered which was to update the sofware. There is no reason your software should be outdated if you were using this receiver before the new smartcard but try anyway as it may SOMEHOW work. Using the remote turn the receiver itself off. Allow the receiver sometime to turn itself back on-this could take awhile so plan this when you leave for work or are going to be gone from the house for sometime so you do not get bored waiting for this to occur. If the receiver has not turned back on in 45 minutes or more then the receiver will either need replacing -which i suggest- or they will try to send you a new smartcard if you talk to Cust service. Tell them you want a service call to fix the receiver. While you have them on the phone verify your receiver number and the new smartcard number which is on the back of the card and ask them to send a hit to the receiver. If the receiver has not been associated with the new smartcard or if the smartcard was not loaded with all of your programmming this should fix the issue. Thanks for using Fix Ya.
Posted on Feb 27, 2009
Anonymous
  • 12 Answers
SOURCE: Need to connect my DSTV decoder through my sony
well this is easier than you think, get yourself a set of RCA's (the red and white and yellow cables that DVD players come with) look behind your decoder and place them colour to colour, then behind your Amp you will read (TV IN) do the same, then with just one yellow RCA plug it into (monitor) that one will then go to the (AV input) behind your TV.. And presto!!! now set your amp input on the remote to TV and your off!! good luck
Posted on May 03, 2010
kukere
SOURCE: no signal from dstv decoder
no signal for dstv for my decorder pls help me.
Posted on Mar 20, 2011
isiakajimoh5
SOURCE: Hi.my dstv remote control is
my dstv remote control function any time it likes.pls what is the solution it is a new machine.Thank you.
Posted on Sep 04, 2011
My dstv is stuck on Channel 101. Remote not changing changing channels. Batteries have been changed and are working! Account is not in arrears?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/
Nov 05, 2016 | Televison & Video
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
Printer Setup & Support Call 1-(805) 225-6690 We are 24 Hour Available Call Now For Help
how can i have codes to tune east african channels plis for free. am using dsd 1131 decoder of dstv. am in johannesburg.
Jun 18, 2010 | Televison & Video
Need to connect my DSTV decoder through my sony amplifier (5.1) not sure of a the cabling or the connections, does someone perhaps ahve a wiring diagram to connect TV, dstv decoder and sony 5.1 amplifier?...
Jun 29, 2009 | Fujitsu Siemens PlasmaVision P42VHA40...
Black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
May 28, 2009 | Sony KP-EF61 61" Rear Projection...
Televison & Video Logo
211 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
