Question about Ps Televison & Video
Onida crt tv ic 9370 ps N3 1717 AV input pin details
Posted by Govind Baghel on
ONIDA ULTRA SLIM CRT TV IC TDA11135/N3/3/AK1 PLAIN SCREEN
IC fault. Replace it. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Oct 18, 2015 | Philips Magnavox 27MS343S 27" TV
Onida crt tv picture ok but no sound .supply also ok I replace sound ic tda2616 I checked both speakers
Have you checked the supply voltage and other pin voltages to this IC? Check it. If all are found OK, and still you do not get sound, main IC is likely to be faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in this key phrase " my service table today " in the search box at the top right of the display window, to get gathered some pages which has the details of practical experiences to the author of that site.
Aug 16, 2015 | Televison & Video
No raster but display and sound ok on lg 21 crt with ic 9370...
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Jul 27, 2014 | Televison & Video
Onida tv 21" crt tv av not working
Check and replace the main syscon IC.
Oct 04, 2013 | Televison & Video
The vertical ic of my jvc tv model no. av f21mx5 are always burn even i replace a new one
Just check the supply voltage input to the vertical IC. If it is more than normal, this type of fault can occur. Just compare this voltage . The TV schematic will help you to find this detail. Check whether the IC is firmly screwed on to its metal heat sink.
Jul 03, 2012 | JVC AV-20020 20" TV
AV 1, AV 2, AV 3, but no TV
that's thing happening you tv epprom ic. replace back same # epprom . good luck!
Mar 21, 2009 | JVC AV-27D302 27" TV
JVC model AV 278p6 standard television
I'll bet you have vertical output IC with some pins not soldered. This IC ( integrated circuit) is a "chip" that makes the picture fill out from top to bottom. After a period of time heat will cause the pins to crack loose on the circuit board. You need to have a tech check it for you. Stargazer
Aug 16, 2007 | JVC AV-27530 27" TV
Televison & Video Logo
284 people viewed this question
Top Ps Televison & Video Experts
Marvin
Marvin
ray gallant
Are you a Ps Televison and Video Expert? Answer questions, earn points and help others
